Old 12-22-2008, 01:23 AM
Default TurboCAD
One of the members was asking about what Cad program I'm using.
see picture.
I think around 1995 the cad drawing programs started using similar functions. my program may not be too much different then other ones.
The program I'm using is called TurboCad v9, I just went up from version 4 pro because I moved up to windows Xp. they may not have updates for the older versions.
It's an old version I think they are up to v15.
On e-Bay they go for $15 to $55.
I don't know now. but at one time they did not all come with a symbol library.
I use electronic symbols, there is others like bath tubs in construction, plumbing.......
There are other TurboCad programs like "TurboCad design" which I don't know what that is compared to the numbered versions Like I have v4-pro, v9.....15.....
There is a few other people on this site that use it. at first It looks intimidating, just as when you first started using a computer.
I only use the basic 2D features which is not confusing. the 3D I have not ventured into, it looks time consuming.
You take it in steps, Lines, circles, squares, colors. if you don't look at it that way it will be intimidating.
The whole rim of the screen is full of function buttons, but I only use about 10 functions and don't look at the rest.
You have the basics, Lines, circles, squares, colors.
Then there is the Snap buttons which makes the program a delight to use.
Example, you have a circle and you want to start a line from the center of the circle, the snap circle button will automatically snap the line to the center of the circle.
Other snap buttons.
snap to a Corner of a box (vertex).
snap to intersection of two lines.
snap to a line.
snap to one of the 4 sides of a circle, left, right, top, bottom.
The snaps take away the guessing of visually trying to attach a line to an object.
The snaps also allow you to place dimensions without guessing where the center of a circle is or whatever.
And it will do the math for your dimensions.
Old 03-16-2010, 01:14 AM
I finally broke down and purchased TurboCad Deluxe 15.
This guy has been selling it for $9.95 for some time and free shipping.
It stated something about a video and that's what I wanted.
I got it fairly fast, his feed-backs are ok but others have stated he will not communicate if there is a problem.
http://cgi.ebay.com/TurboCad-Deluxe-...17684831529158
If its sold, search e-Bay later he keeps relisting it.
Well the video is very good but only covers 2D I really wanted it on 3D as I don't want to read the manual.
It comes with one DVD with two serial numbers, one for the TurboCad and one for the video.
I called up the 800 number to TC and got the activation codes, other wise you can only use it for 30 days.
I gave the person on the phone the serial numbers and he gave me the activation code for TurboCad Deluxe 15 without question.
The serial number I gave him for the video was wrong or no good and he gave me a serial number and activation code that worked for the video. no questions asked.
The Video is called "CAD Fundamentals Training" and is run from the DVD.
The 16 digit serial number on the video has to be entered without any dashes and the activation code has to have the dashes, go figure.
The video states versions 7 to 12 but they state it also covers higher versions.
Either way the Video is very good and is very step by step for the beginner (2D video only).
The English accent of the instructor is amusing.
Best to run it at 1024x768 resolution and a 17" or larger monitor.
You don't have to learn everything at once, just go back to the video for what you want.
I guess I have to read the 3D instructions some time.
Old 03-16-2010, 07:11 AM
engineman56's Avatar
Nutbuster
GWIZ, This is why I wanted a lap top computer is to run Autocad, and do drawings. I need to learn this too. Kevin
Old 03-16-2010, 07:43 AM
Tom Zachman's Avatar
Dodge City Marshal
Newer operating systems coupled with programs like AutoCad will require lots of Memory.
Laptops and notebooks are typically very short on memory.
New sig line:
Old 03-20-2010, 03:54 AM
This is just some simple 3D items that I clicked on and moved them around. didn't know I could put a cone thru a block. Like I said I don't know much about the 3D.
1)Note the shadowing,
2)also you can move the part around in a full 360º ball.
I should be able to move the lighting around when I learn more.
As for memory, I only have 512 mb and a pent4, 2.4Ghz machine.
I would think the memory has to do with how complex the drawing is, and the speed of the machine may effect how fast you can rotate the drawing.
This is some of what the package states On the turbo cad Deluxe 15.
They say 512 Mb (2 Gig recommended memory).
2 Ghz minimum speed.
1024 x 768 monitor
16-bit video card (3D graphic accelerator card recommended)
Name:	3D cad a.jpg
ID:	58711   Click image for larger version
Name:	3D cad b.jpg
Old 03-20-2010, 11:52 AM
G, I think you should add memory.
Old 03-22-2010, 01:01 AM
That's a peer pressure thing.
A while back I did look into it, but it got stupid.
Dell did not splain the details like ECC, buffered, Voltage, high-density or low density, CL2.5 or CL3........
Eventually I will get more. on my last computer more memory did not do much.
Old 03-22-2010, 01:33 AM
MrRodeoCC MrRodeoCC is offline
Unfortunately most laptops require removing memory (ramm) to be able to add memory, since they only have one swappable memory slot, unlike towers which usuallu have 3 or 4 ramm slots. The first thing to do would be to decide if the laptop or tower is worth updating, or replacing the whole unit. I know that sounds drastic, but trying to update an old system with just memory wont get the performance you want to rub the new operating system and programs. It may improve some but the other factors like a single core processor, older chipsets, single channel memory, etc will still limit performance. If you are up to it, you can build your own pc by following instructions from a source like pc mechanic, thats where I learned how to build and repair pc's which is one of my hobbies. Here's a link to the how to page, lots of good information, even if you are just upgrading a part, the build explians the steps of installing that part.
http://www.pcmech.com/byopc/
Jody
Woodworker Enthusiast, Welder Newbe
Hobart Handler 140, 4 1/2" B&D Grinder, HF 4 1/2" Grinder.10" Table Saw, Drill Press, Compound Sliding Miter Saw, Planer, Joiner, Routers, Wood Lathe, other misc saws and tools, clamps galore
Tags
cad
