Old 05-21-2020, 09:49 AM
trooper1954 trooper1954 is offline
Default CH 2610 Compressor air leak at breather cap
Hi all,
Finally found a blower fan for the above compressor, but now, when it's running, there is a small amount of air blowing by the breather cap.....was wondering if this is normal? The compressor runs well, and holds pressure otherwise, but not sure if this is a problem, and if so, what the fix is?
Thanks for any help.
Old 05-21-2020, 12:29 PM
I'm not sure what the fan has to do with the blowby unless you're saying that you hadn't run the compressor till you got the fan. In any case, a little bit of blowby shouldn't be the end of the world. Depends on how old the compressor is, how old you are and how much longer you want to run it.
We've got an old deVilbiss compressor in the shop that we bought used 22 years ago and it was probably 20 years old when we got it. It didn't have a filter on the air intake and I never got around to putting one on but it still makes 140-150 lbs. of air when we need it. And yes, it does have a bit of blowby...
Old 05-21-2020, 01:00 PM
Thanks Keith,
Yes....the compressor is 20 years old but in excellent shape. I don't mind the little bit of blowby as it runs so well, but was concerned that I might do further damage by running it like this. It will never be doing heavy duty work, just short sessions maybe twice a week, so from the sounds of it I can just keep going?
It has been idle for two years and got damaged in a move....the blower wheel cracked and had to be replaced...I didn't want to run it without cooling for the pump so waited.
Thanks again for the input
Old 05-21-2020, 02:53 PM
Make sure oil level is correct...
Old 05-21-2020, 03:09 PM
mccutter,
old oil drained, and fresh oil put in....bang on the "oil level" mark.
Thx
