Old 05-14-2020, 07:55 AM
tnmike's Avatar
tnmike tnmike is online now
Sultan of Scrounge
Default Disc Harrow Identification
Does anyone know the make and model of this disc? Im pretty sure it's International but can't find a tag on it.
ID:	156106   Click image for larger version
ID:	156107   Click image for larger version
Klaatu barada nikto
Old 05-14-2020, 08:16 AM
I had one like that a few years back. No ID on it, but also thought it was International. Bought it for $25 and sold it for $75. Sure wish I had kept it. Have needed it several times since.
Old 05-14-2020, 08:36 AM
tnmike's Avatar
Sultan of Scrounge
You stole that. Shoulda kept it. Mine needs help. Discs. Bumper washers. Not sure until it comes apart. Check,new and used prices. High
Klaatu barada nikto
Old 05-14-2020, 10:28 AM
Might be a International 1 Point Fast Hitch Double Gang Disc Harrow
Old 05-14-2020, 10:56 AM
They usually had ‘IH’ somewhere on castings, at least on a lot of them.
Dearborn usually had a tag on the upright three point hitch arms with rivets.
Case is the only other one I recall as red offhand, though there were lots of different manufacturer’s through the 50’s and 60’s.
Old 05-14-2020, 05:30 PM
I cant say who made it but I got one just like it, well maybe a bit more beat up.
Old 05-14-2020, 09:48 PM
tnmike's Avatar
Sultan of Scrounge
Not a fast hitch but looks similar. Mine is 3 PT hitch. Tore into it today. Front two sections were a mess. Worn bearing halves and broken spool bearings. Discs had spun on the axle because someone place the shaft in the wrong hole. Ordered everything from Agri Supply. New axles, discs, bearing halves and bearing spools. A LOT cheaper than a new disc harrow..
Klaatu barada nikto
Old 05-15-2020, 11:58 AM
If there was only one or two discs that had spun, we would weld them up and grind them back to size.
The other thing that we ran across quite often was not enough washers under the axle nut, so the nut would ‘tighten’ but actually be bottomed out, and the discs would wiggle ever so slightly and wear into the axles.
We had a bucket of large washers just for that, any that we found went into it.
