Old 05-06-2020, 09:25 PM
docweathers docweathers is offline
Default Old compressor developing rust leaks
I have an old air compressor that is developing small rust leaks at the bottom of the tank. I was wondering about the feasibility of pouring some kind of sealant, glue, or gunk into the tank to seal it so I can milk it for a couple more years of use. I would appreciate any thoughts on whether this would work and suggestions on what type of goop would be best.
Old 05-06-2020, 09:40 PM
Junk it now.
A 50 gallon air tank at 100 psi has the stored energy of 4 sticks of dynamite.
Here's what happens when a tank fails.
https://www.youtube.com/watch?v=KVP_A7eGYxw
Old 05-06-2020, 09:42 PM
I would start looking for a replacement tank . When one lets go if a instant failure it can get messy .How big are we talking 20 gallon,60 gallon ?
Old 05-07-2020, 12:03 PM
I hope your grandfather was not seriously hurt by the tank explosion.
This is a 20-gallon tank on an ancient air compressor which I bought used 10 years ago for a hundred bucks. It has served me well. Both it and I have a limited more time in the shop. I don't want to invest in a new air compressor or tank.
Where the compressor sets, in a corner under bench, would keep an explosion from causing more than a harrowing shock. Currently, it is just a rather slow leak and my use of it is quite intermittent. So, the leak is more of an annoyance than a real obstacle to having compressed air when I need it.
Old 05-07-2020, 12:31 PM
astronut's Avatar
astronut astronut is online now
Junk it now.
Wow, just wow! That was wicked!
Lincoln Weld Pak 100
Giant Tech Arc 200
Miller Roughneck2E
Old 05-07-2020, 01:20 PM
Dr Dean's Avatar
Dr Dean Dr Dean is offline
no bull it's huge!
Doc, there's a lot of times that I would think things would be fine or just go for it even when everyone around me is scared shit less. This however is NOT one of those times. Don't fool yourself about something like a workbench being able to contain that bomb going off unless you are wanting to meet Jesus face to face sooner rather than later. I have seen the aftermath and found pieces over 1/4 mile away from the building it was in.
Old 05-07-2020, 03:24 PM
Should be a lot of 20 gallon compressors in junk . Look if we ever get back to living for a oil less that died quick with a good tank .
Old 05-07-2020, 04:41 PM
Plus one one this. My grandpa had an ancient craftsman 20 gallon compressor that he had bought new and the tank rusted out and developed a leak. He bought a new CH 20 gallon oil less compressor at lowes to replace it and it burnt up in short order before he even had a chance to throw the craftsman away. I took the motor and pump off the craftsman and mounted them on the CH tank and grandpa had a good compressor again. It lasted the rest of his years and it now is in my shop. I the cheap oil free pumps on anything larger than a pancake compressor are prone to abrupt failure and the compressors get thrown away regularly.
Old 05-07-2020, 04:59 PM
I just get a propane tank pull the valve clean with solvent and dry then slosh some paint in it and set it in the sun to heat cure .voila a rust resistant pressure rated tank with 3/4 npt threads.
I mount them with the port down so no moisture stays in the tank.
There are two standard for such tanks general purpose 250 PSIG rated and over the road licenced at 312 PSIG.
when picking used tanks look at the tare weight for a given size (volume) the heavier tank will be thicker. I would not weld on such a tank but welding on the attached gaurds is ok as long as the tank is sealed and you do not get the tank hotter than you can touch.
We had a major forest fire go through a town about 45 miles from here.
An empty 1500 gallon tank bleve (boiling liquid expanding vapor explosion)
we heard that bang here.
Old 05-07-2020, 10:09 PM
Smile Good advice
I am not going to screw with sealing the tank. You guys may have saved me a trip to the morgue. Harbor Freight has a cheapie that will work for my minimal use.... plasma torch and spray booth.
Tags
compressor, rust
