Old 05-02-2020, 06:28 PM
trooper1954 trooper1954 is offline
Hi Digr,
Approx. measurements are :
Wheel Diameter inner edge 7 3/8"
Wheel Diameter outer edge 7 3/4"
33 blades 2 3/4"long x1" wide
Width 2 7/8"
Does this help? Let me know if I missed something.
Thanks
Old 05-02-2020, 07:18 PM
what size shaft does it mount on?
Old 05-02-2020, 11:48 PM
Just create an air leak in the high pressure line before the check valve and let it blow to cool it down.
Old 05-03-2020, 08:10 AM
randydupree's Avatar
Why, Hell Yes!
I would have a house style box fan or something on that before dark.
What does surplus center have for a 120v fan?
I think the fan should run after the compressor kicks off anyway,kicking off just when the compressor is at its hottest is dumb,it needs a cool down time period.
Old 05-03-2020, 09:49 AM
Hi digr,
shaft size is 1/2"
Thanks
Old 05-03-2020, 09:53 AM
Randy and Walker,
Not really sure what you guys mean....I'm a bit challenged with words ....prefer pictures!!
Could you explain ...the compressor is 220v by the way.....does that make a difference to a 110v fan, or is the fan powered independently from the compressor?
Thanks again.
Old 05-03-2020, 01:14 PM
Originally Posted by trooper1954 View Post
Randy and Walker,
Thanks again.
I think walker was saying just put a hole in the air line to blow on the compressor head to cool it down. I think he was joking, because the compressor would never shut off with that hole though.
You could easily run a 120v fan on that compressor. You just tie into one of the hot wires, and then the neutral wire to run the fan. There are two 120 v wires that make up the 220 (240)v power.
Old 05-04-2020, 04:12 AM
Randy and Walker,
Thanks again.
use two fans wired in series 120 +120 = 240 volts.
BUT
the two fans must be identical no mixing.
