Old 04-30-2020, 10:25 AM
Default A Different KInd Of Burner Adapter
We have a job coming up, where the customer ordered the boiler directly from the manufacturer, then as an after thought bought the burner directly from a totally different manufacturer. Unfortunately, while they both have the same BTU rating, they do not exactly fit together, their only options are to either, (A) buy another burner (roughly $21,000) or (B) have us make an adapter to make them fit and work together (roughly $2000-$3000). They selected option B.
1 - laid out the bolt holes on boiler plate
2 - laid out the bolt holes and pilot cut-out for burner plate
2 - the plate to the boiler cut out and bolt holes drilled
3 - the plate the burner will bolt to, cut-out, with pilot cut-out and bolt holes
ID:	155829   Click image for larger version
ID:	155830   Click image for larger version
ID:	155831   Click image for larger version
Old 04-30-2020, 03:50 PM
5 - welding in the boiler mounting plate
6 - welded
7 - the burner mounting plate, with the studs welded in
ID:	155837   Click image for larger version
ID:	155838   Click image for larger version
Old 04-30-2020, 03:54 PM
8 - welded together
9 - the back side of the adapter
ID:	155840   Click image for larger version
Old 04-30-2020, 04:41 PM
Another nice job!!! I have been using a drill with a small center drill in it instead of a center punch and it works good. I can no longer hold a hammer in my right hand due to arthritis and my left hand has no idea how to use a hammer. Try it I think that may like it.
Old 04-30-2020, 06:25 PM
randydupree's Avatar
Why, Hell Yes!
It sure seems like your customers like to do shit the hard way?
Old 04-30-2020, 06:41 PM
I hope they understand that they really did save money . Sometimes bidding out is not the wisest thing to do .
Old 04-30-2020, 07:38 PM
What color paint ?
Me thinks bronze or gold.....
Old 04-30-2020, 07:44 PM
What color paint ?
Minion Yellow
Old 04-30-2020, 07:51 PM
It’s leaving here, the same color the steel company sent it out of their plant......
