Old 04-26-2020, 09:49 AM
trooper1954 trooper1954 is offline
Default Compressor question
Hi all,
Just have a quick question about a compressor attachment. I have only had experience with really small compressors and have recently acquired a used Campbell Hausfeld 5hp. In the photos included is an attachment that came with the compressor.....can I assume that it will connect to the same outlet as the older one in the photo?
Thanks.
PS. Tried to send this to the forum last night but for some reason it doesn't appear.....sorry if it's duplicated somewhere.
Name:	Existing outlet.jpg
ID:	155780   Click image for larger version
Name:	New outlet.jpg
Old 04-26-2020, 10:57 AM
Originally Posted by trooper1954 View Post
Hi all,
Thanks.
I don't think outlet is the right term, outlet I think electrical. The original
equipment is a regulator, generally compressors will produce pressure higher
than most your needs so a regulator is able to reduce that pressure down to
your working pressure.
Now the new unit you have is an FRL; Filter Regulator Lubricator. They
should be put in that order (they are not in that order in your picture);
Filters also often will remove any condensed water as well.
I have a filter and regulator on my compressor but only lubricate at my point
of use. That is because the air I use is most for operations other than
pneumatic tools. Also I don't want all my air lines and hoses filled with oil.
So I will either lubricate my tools at the tool or in the case of my mill I have
the lubricator installed on my mill so only the lines that need it are lubricated.
Old 04-26-2020, 12:00 PM
The first picture is a combination air filter and pressure regulator, you turn the black knob to set the working output pressure you need.
Second picture, search the net with the model numbers may come up with a manual.
Old 04-27-2020, 10:07 AM
Default Re: compressor question
Thanks guys,
Since discovered the previous owner was an autobody man, and that the attachment I asked about was bought for mostly spray painting and so has a regulator, water filter and particle filter.....no oiler.
Can I assume then that in this situation oil at the tool would be the way to go?
Thanks.
Old 04-27-2020, 10:48 AM
Thanks guys,
Thanks.
Yes, oil at tool. A few drops directly into the male fitting at the tool. The fitting will go into a female coupler on the hose. Run the tools a few times with a rag over the exhaust so you don't get oil vapor (vapour ) all over everything.
If you have issues with moisture in the air and need dry air to paint or plasma cut, consider investing in a "Motor Guard" type cartridge filter/water-separator.
It is not advisable to hang a hose on the outlet tube as shown in your picture. That is an unplanned excessive air release (explosion?) waiting to happen.
Old 04-27-2020, 11:02 AM
Thanks.
That is what I do, tools are only about 25% of my use. Plasma cutter and
filling tires make up the majority of my usage so dry lines are important.
Old 04-27-2020, 11:05 AM
+1 on that!
Old 04-27-2020, 11:40 AM
Thanks guys....my bad!!! Hose already removed!!!
