  #41
Old 05-01-2020, 05:33 PM
All walls covered with OSB. House wrap installed. Cedar fascia installed. Auction day tomorrow.
  #42
Old 05-08-2020, 04:27 PM
After a few days of winds and rain, finally found time to get some things done on the shed. Window tape on, entry door finished, roof water barrier on. Next to work on the double doors and roof tin.
Forgot the new camera so back to the phone.
ID:	155969   Click image for larger version
ID:	155970   Click image for larger version
  #43
Old 05-08-2020, 04:41 PM
Throw an RV toilet, army cot and a propane hotplate in that. You can make 800-1000/month on that in Estes.
  #44
Old 05-13-2020, 05:41 PM
Got the tin done on the roof roof less the trim piece at each end of the gables because I forgot to take out the dual saw. Finish off the roof tomorrow.
Started on the double doors. 3/4" plywood core with 2x4 framing and old barn wood will go in the inside of the 2x4 framing. After first one, I have to build the second one. Had a 2 hour delay due to a rain shower.
Someone please tell me I am having fun!!!!!
ID:	156100   Click image for larger version
ID:	156101   Click image for larger version
ID:	156102   Click image for larger version
ID:	156103   Click image for larger version
  #45
Old 05-13-2020, 08:51 PM
Looks like you are having fun from here.
Isn’t it better working for free than for a paycheck?
  #46
Old 05-13-2020, 09:12 PM
Oh, he will pay.
  #47
Old 05-13-2020, 11:53 PM
Looking good, getting near to done. What's going on the walls, steel?
Tell Scott hi
  #48
Old 05-14-2020, 04:00 PM
Tell Scott hi
He is going to put on saw mill wood slabs so it looks like a log-cabin. Roof is all done and trimmed. Double doors next. Wood siding slabs last. Scott calls it his tiny house.
  #49
Old 05-16-2020, 05:40 PM
All cut for one door. The angled barn wood was a bitch to fit. Wood is all warped and cracked. He does like the look though. Center section had different angles on each side, as it was a rectangle instead of a square like the top and bottom sections.
Now he has to stain the 2x4 with some antique color to try to match the old barn wood. Then seal the whole assy so water does not get to the plywood core. Then put the barn wood back in and apply a few coats of Thompson Water Seal. Then mount the hinges to the door and then to the shed.
ID:	156150   Click image for larger version
ID:	156151   Click image for larger version
  #50
Old 05-27-2020, 11:44 AM
Got the doors all stained and hung. Still some trim and a latch for Scott to do. Next the sawmill log slab siding.
ID:	156283   Click image for larger version
