Old 04-07-2020, 11:06 AM
If you could fine a 2 or 3 speed motor that would be ideal.
Looks like your headed in the right direction.
Old 04-07-2020, 11:18 AM
Yup don't build it like the one I did whenever you had to use it, it had to be chained down otherwise it took off and ran around the yard and then ya worked up a sweat just trying to catch the dam thing... unless the extension cord ya used that day happened to be a short one
Don't know what the ratio was but was 2-1/2' small pully top pulley was 10"
separated by about 30 inches apart 54" fan from an army base off a chiller cooling unit... put a 2hp 1735 rpm motor on it.
turn it on in the shop and everything became looking like something out of a Jumanji movie... monkeys and the ex flying around on brooms and shit!
Old 04-07-2020, 02:20 PM
randydupree's Avatar
Why, Hell Yes!
One of the most impressive air movers I’ve seen are ceiling fans called ‘big ass fans’. Look them up. As Randy says, not necessarily fast, though they move a lot of air.
Not cheap,but bigassfans are awesome.
I have too much shit hanging from my ceiling to use one.
Plus i leave in the summer,i work in the winter these days..
Old 04-07-2020, 04:05 PM
Looking at it more I think it needs bearings.
My suggestion is spend the $100-$150ea for decent stand-up fans and be done with it. My small shop has 3 fans in it so even 1 fan for you isn't going to cut it. Sell that fan at your first yard sale or put it in the "project" pile.
NOW is the time to be buying fans before the summer heat commences and Chinese inavailability affects prices...
PS: the same goes for window A/C units...
Old 04-07-2020, 09:10 PM
OldRedFord's Avatar
Kibble King
I would slow the fan down,i like a nice gentle breeze,not a hurricane.
With speed comes noise,and you can't weld anywhere near the fan.
If your trying to dry a wet floor,you need high fan speed.
Now if your going to mount this fan way high in a wall and have it suck out,high speed will be better,except for the noise.
I was assuming (bad thing) that you were planing on mounting the fan on a cart with wheels so it can follow you around the shop.
Ceiling fans would be a better choice.
A friend had a old worn out wood airboat prop mounted on a stand,it turned slow but moved a lot of air,and it was quiet.
That prop may have been 80'' .
That's the plan. Mount it on wheels. Ceiling fans or air conditioning in the shop can come later.
I will say it seems with the big 6" thick slab I have it takes a bit for the building to get hot inside.
Tim
Old 04-08-2020, 08:24 AM
Why, Hell Yes!
Yep,the slab is cool now,but soon it will be hot! Keep the sun off the floor and you can keep it cooler.
Before the hurrican blew my roof and all the skylights off my house floor would get hot under the skylights.
When i rebuilt the roof i put in dormers,the light it better and the sun is not shining right on the floor,the floor is much cooler.
Keep the doors on the sunny side closed when you can.
Old 04-26-2020, 09:24 PM
OldRedFord's Avatar
Kibble King
I ended up with two more of the same size and model fan. Need motors.
Tim
Old 04-27-2020, 06:13 PM
12345
Old 04-27-2020, 08:17 PM
OldRedFord's Avatar
Kibble King
12345
They were free.
Tim
Old 04-28-2020, 07:49 PM
OldRedFord's Avatar
Kibble King
Building a box. Using a table saw motor for power. The rpm is 2× but I already had the motor and think if I use a pot to control speed I'll be fine.
ID:	155803   Click image for larger version
Tim
