Old 04-04-2020, 10:42 PM
:d
lol I know how to figure ratio, it's ration that I have a problem with.
I guess you did not like my answer...
Originally Posted by chumly2071 View Post
All the 36s we built were 1/2 hp. Being a belt drive, and looking at the number of blades, I'm going to throw a guess of 600-650 RPM. Put a pulley on the motor, and do a quick clamp on ammeter check to see if you're where you need to be. Ideally you'll have a specific speed for a blade at a certain static pressure to give you the best efficiency. As a box fan moving air, static pressure is a moot point. Don't spin it too fast (whatever yhe real rated speed is) as the blades can fatigue crack and exit spectacularly. Any markings on the fan to id make and model?
Engineers...
Old 04-04-2020, 11:10 PM
chumly2071's Avatar
Urban Gunfighter
Engineers...
It's not like I designed these things or anything...
Old 04-05-2020, 12:02 AM
No, you just like blowing up transformers...
Old 04-05-2020, 12:05 AM
chumly2071's Avatar
Urban Gunfighter
That too. I was very good at it.
Old 04-06-2020, 08:26 AM
OldRedFord's Avatar
Kibble King
All the 36s we built were 1/2 hp. Being a belt drive, and looking at the number of blades, I'm going to throw a guess of 600-650 RPM. Put a pulley on the motor, and do a quick clamp on ammeter check to see if you're where you need to be. Ideally you'll have a specific speed for a blade at a certain static pressure to give you the best efficiency. As a box fan moving air, static pressure is a moot point. Don't spin it too fast (whatever the real rated speed is) as the blades can fatigue crack and exit spectacularly. Any markings on the fan to id make and model?
Sent from my SM-G920V using ShopFloorTalk mobile app
Yup.
Twister model A36G
Acme Engineering & Manufacturing Corp
Tim
Old 04-06-2020, 11:45 AM
chumly2071's Avatar
Urban Gunfighter
Looking back trough an old University of Illinois fan performance book (results tabulated in 1999 from several years worth of tests (I worked in the lab that did these tests while I went to school, and it got me my first job out of school)), it looks like most of the belt drive ACME stuff was 580 or 635 RPM (back then, anyway).
These were all fan panels in housings with an inlet shutter for AG applications.
I'd put a 1/2 HP 1725 motor on, Totally Enclosed Air Over (TEAO) and shoot for the 580 range and then check the amperage the motor is drawing. Speed up or down with pulley changes based on comparison to the motor rated amps. A Magnetek C580 would be a good choice, but is an old catalog number.
A lot of the product shown is still mine (from over 20 years ago... AP and Cumberland
Old 04-06-2020, 09:10 PM
OldRedFord's Avatar
Kibble King
So a 3" drive pulley on the 1725 rpm motor would be a good start.
Looking at it more I think it needs bearings.
Tim
Old 04-06-2020, 11:42 PM
...So a 3" drive pulley on the 1725 rpm motor would be a good start...
That would be a good start--should give you about 575 RPM...
Old 04-07-2020, 09:14 AM
randydupree's Avatar
Why, Hell Yes!
I would slow the fan down,i like a nice gentle breeze,not a hurricane.
With speed comes noise,and you can't weld anywhere near the fan.
If your trying to dry a wet floor,you need high fan speed.
Now if your going to mount this fan way high in a wall and have it suck out,high speed will be better,except for the noise.
I was assuming (bad thing) that you were planing on mounting the fan on a cart with wheels so it can follow you around the shop.
Ceiling fans would be a better choice.
A friend had a old worn out wood airboat prop mounted on a stand,it turned slow but moved a lot of air,and it was quiet.
That prop may have been 80'' .
Old 04-07-2020, 10:23 AM
One of the most impressive air movers I’ve seen are ceiling fans called ‘big ass fans’. Look them up. As Randy says, not necessarily fast, though they move a lot of air.
