Old 04-24-2012, 07:39 PM
Default Grader mast
I was asked to make this mast removable without taking off the undercarriage making it easier to handle when removing in the spring. It had enough braces on it so I decided to cut and weld it in place. I put a jack under it to help support it and cut it apart I used two 3/4" plates bolted together to make the separation. When I am done I have to take it off and make a stand for it when they store in the yard. I think the stand will be a bigger job than the plates. This is what I have done so far.
1-2 Mast
3 Burning the plates
4 Drilled on the mill (bad pic)
5 Plates bolted
ID:	90185   Click image for larger version
ID:	90186   Click image for larger version
ID:	90187   Click image for larger version
Name:	4 drill.jpg
ID:	90189   Click image for larger version
Name:	5 bolted.jpg
Old 04-24-2012, 07:44 PM
More pics
1-2 Layout
3 Jack for support
4-5 First cuts
Name:	6 layout.jpg
ID:	90191   Click image for larger version
Name:	7 layout.jpg
ID:	90192   Click image for larger version
ID:	90193   Click image for larger version
Name:	9 cut 1.jpg
ID:	90194   Click image for larger version
Name:	10 cut 2.jpg
Old 04-24-2012, 07:51 PM
More pics
1 Last cut on bottom Very little movement
2 Opened up
3-4 Sliding in the plates
5 Welding
Name:	11 cut 3.jpg
ID:	90196   Click image for larger version
Name:	12 cut 4.jpg
ID:	90197   Click image for larger version
Name:	13 plates.jpg
ID:	90198   Click image for larger version
Name:	14 plates 2.jpg
ID:	90199   Click image for larger version
Name:	15 weld 1.jpg
Old 04-24-2012, 07:53 PM
More pics
1-2 Welds
Name:	16 weld  2.jpg
ID:	90201   Click image for larger version
Name:	17 weld 3.jpg
Old 04-24-2012, 08:02 PM
Nice clean surgical work there Digr. Well done.
Old 04-24-2012, 08:34 PM
goulet!'s Avatar
goulet! goulet! is offline
Send a message via Yahoo to goulet!
Very nice!
Sent from my iPhone using SFT
Matt Goulet
Old 04-24-2012, 08:56 PM
Nice professonal job. I think your right about the stand for storage. It will take more steel, braces and welding than this job.
Old 04-24-2012, 09:03 PM
Jim-TX's Avatar
Jim-TX Jim-TX is offline
Chairman of the Headboard
Nice work. Welded with 7018?
Jim
Old 04-24-2012, 09:05 PM
No I used .045 dual shield
Old 04-24-2012, 10:05 PM
Nicely done, it should stand up well.
