Old 07-29-2010, 11:57 AM
Caliber's Avatar
Caliber Caliber is offline
Originally Posted by panhandle_redneck View Post
I don't know. I just cant get my head wrapped around what I think is the best way and go with it.
When I was driving over the road, the pit style dock leveler was the best system. I liked the simple spring assist lift units, they had a ring attached to a chain in a recess hole that you pulled and it released the lock and allowed the ramp to pop up. Once it was up, you step onto the ramp pushing it back down at the same time the leveling plate swung out a caught the back floor plate on the trailer (the hinges are a piano type, designed to carry weight and stop when laid out flat 180*) When you where done, the truck pulled away and the leveling plate dropped back down 90 degrees, the ramp would then lay flat at floor level.
Not to be a wet blanket,,,,two things,,,, these ramps have allot of engineering to them. They must carry allot of weight, (forklift, forklift and load) the lift mechanism must work like clockwork. Second,,, liability,,, OSHA has a ton of rules on docks. For the time you'll have building it will be cheaper to buy a unit.
"Government is not the solution, it is the problem!" RIP Ronnie,,,
Old 07-29-2010, 06:58 PM
Norm W's Avatar
Norm W Norm W is offline
Caliber, I hated those spring loaded dock levelers, if I was using a hand truck for loading. They popped up OK, but I had to find something heavy to carry to get them to go down. A hand truck with a mattress on it, plus my weight wasn't enough. I needed more lead in my butt.
Norm
Old 07-31-2010, 12:37 PM
kbs2244 kbs2244 is offline
Default draw bridge
Back to the draw bridge idea.
Check out what I think the call a Bastille bridge.
(That is French spelling, and I am not even good at English.)
All the bridges across the Chicago river are this style.
So you can start looking there.
All mechanical.
A big quarter gear below the surface raises it almost vertical.
They have twin leaves meeting in the middle but, for your length, it could be done with one.
Old 07-31-2010, 02:49 PM
panhandle_redneck's Avatar
panhandle_redneck panhandle_redneck is offline
Thanks. I will check that out.
I hear and I forget.
I see and I remember.
I do and I understand. --Confucius
Old 04-24-2020, 08:14 AM
goldengaterack goldengaterack is offline
Default forklift dock plate
I read all the questions of yours and suggestions about the forklift dock plate but I'm also in this field and I also manufacture the dock plate. These are not the whole information about forklift dock plates If you need more information about dock plates then visit us.
Old 04-24-2020, 08:55 AM
Originally Posted by goldengaterack View Post
I read all the questions of yours and suggestions about the forklift dock plate but I'm also in this field and I also manufacture the dock plate. These are not the whole information about forklift dock plates If you need more information about shit eating spammer then visit us.
WoW !
A spammer dredging up a 10 year old post to crap all over it.
I sure hope you realize how badly your damaging your companies reputation
with this crap.
sometimes I have to spec these things out for work, and now I have just eliminated your company from ever getting a look.
Old 04-24-2020, 09:58 AM
Guess folks are getting bored and trying to drum up business however they can.
Old 04-24-2020, 10:17 AM
That don't make it justified eh ?
