Old 03-11-2019, 05:02 AM
clive's Avatar
clive clive is offline
Default Bandsaw mod
Made this mod up ages ago, it allows me to put 5 lengths of 12mm round in the saw at once, the clamp lines up the steel in the right position before I put it in the vise. I use two clamps and just slide the one closest to the saw back each time. I get the steel cut to 2 metres at the steel supply which makes it easier to handle than the full length. Very handy when you want to cut up to a hundred pieces
And as usual no matter what I try it is the wrong way round.
ID:	149861   Click image for larger version
It's So Easy
Old 03-11-2019, 05:52 AM
Neat idea.Thank you for sharing.Click image for larger version
ID:	149863Click image for larger version
Old 03-11-2019, 11:20 AM
+1... Great idea an time saver... one cut, all cut the same length
Thanks, Clive. For sharing that, ill have to swipe that and use it...
Old 03-11-2019, 03:12 PM
digr digr is online now
Nice setup!!!!
