Old 03-11-2019, 01:03 AM
Scott V's Avatar
Scott V Scott V is offline
I use both styles of holders.. My TG-100 collet hold things so tight, it's hard to remove the end mills,etc.. Have to remove the #40 taper to get them out half the time.. Movement is not a issue, lack of it is..
Old 03-11-2019, 01:51 PM
By all means give them a try--I think you'll like them. Make your DOC about 2-3X the diameter of the cutter; spin them at 150-300 RPM (depending on cutter dia.); feed them pretty heavy and watch the chips pile up. With a little experimenting you'll quickly find the sweet spot. You can tell you've got it right when the cutter just chugs along with no sign of a struggle and lays down a pile of chips. On a smaller, lighter machine you won't find anything better for mass material removal...
There is nothing like a 1 hp cut with a cobb mill on a 3/4 hp machine to bring forth the magic smoke. as far as slipping between tooling and holders a little silphos makes the tools stay put for ever
A trick i have seen to reduce slipping is to paint the tool shank with a black felt marker and insert it into the holder while wet and tighten it ASAP.
Old 03-11-2019, 02:02 PM
Doesn't your collet chuck have a retaining ring that you have to snap your collets into, it opens the collet when removing the cutter.
Old 03-11-2019, 04:18 PM
Scott V's Avatar
Has a ring, just tight when I unscrew it a turn.. Just did not want to force stuff too much. It's generally the bigger shanks that cause issues. I am going to swap over from end mill holders on the machine, and try it again to see if it will break free ..
Old 03-11-2019, 04:33 PM
When I first started using mine I didn't know about the snap ring that holds the collet and had a hell of a time getting stock out of it, I had to take it off and knock it out with a punch.
Old 03-11-2019, 05:07 PM
That first turn or so takes the slack out. When it tightens up, is when the nut is preparing to pop the collet loose. Sometimes I’ve even seen a tap with a hammer on the wrench be needed to crack it loose.
If you need both hands, put a piece of wood or plastic under the cutter, as they will sometimes fall out when it pops.
Old 03-11-2019, 08:44 PM
Scott V's Avatar
My collets are brand new, so maybe they are a bit tight.. I put a bit of lube on the cap, and tried it again, broke free this time.. Just did not want to beat on the old girl..
I am mostly using it with annular cutters, and nice option to have..Although I do have a Nitto Kohki auto mag drill too.. It only goes up to 1-3/8 X2 " The mill will swing a monster bit.. Kicking butt on the Amazon cutters.. Like a 2"X3" USA made carbide for $20.85 About $200.00 anywhere else on the web.. I am still careful handling them and make sure thy don't drop out.. Even though it's only $20.00 not too many deals on those..
