Old 08-15-2019, 08:25 PM
Wink Night of 1000 Cuts! (NOT Lingchi!)
Night of 1000 Cuts! (NOT Lingchi! )
Well actually, only around 750. And began around 11am when the truck dropped off the stock. Turned off the lights at 3am...
Old Delta 36-070 10" saw using 8" 18T "surplus" Milwaukee carbide blades of which I have many dozens. Lose a tooth here and there. I usually stretch them until 4-5 teeth are gone. Usually go through 1 blade a session.
You can see the adjustable stop I made. Also has a "clamp" to hold the ends of small parts. It will cut slivers if I need it to. The one shown is about 3/32" thick, 2x1x1/8 channel from cutting a slightly over length piece. The saw HAS cut thinner.
You can also see the repurposed dot-matrix printer cover I use as a chip stop. Generated about 5 pounds of cuttings--should I save it?
Al stock is a mixture of 6061 and 6063. Flats, rods, channels, angles and tubes (sq & round). About $800 sitting there...
That ol' saw has been chugging along for 18 years or so. 10s of 1000s of linear feet of stock. Around 5000rpm so safety gear in use! I have 2 other working Deltas for backup: one exactly like this one and one slight newer with tilt but the motor is the same. Probably time to treat this one to a new set of brushes, maybe a new switch although I DO have an additional spare motor and parts.
ID:	151829   Click image for larger version
ID:	151830   Click image for larger version
ID:	151831   Click image for larger version
ID:	151832   Click image for larger version
Old 08-15-2019, 09:09 PM
JBFab JBFab is offline
What ya building??
Sent from my mobile device using ShopFloorTalk mobile app
Old 08-16-2019, 11:15 AM
Originally Posted by JBFab View Post
What ya building??
I will venture a guess “MC Cutters”.
Old 08-16-2019, 07:30 PM
What ya building??
"Leetle Pieces"
Old 08-16-2019, 09:01 PM
What ya building?
MC Cable Cutter & Pigtailer The inventor, my late FIL, named it. It is what it does...
Old 08-16-2019, 09:54 PM
That's pretty dam slick there! mccutter, very nice idea...
Old 08-16-2019, 10:18 PM
Well, well. I recognize your forum handle now.
Had now idea they called it a whip, I always called it a pain in the ass to deal with- armored cable.
