Old 10-31-2018, 03:25 PM
Default Lathe Chuck Key
Been wanting to do this a far a few years. The old chuck key was too short and you would hit your hand on the corner of the lathe control box when the chuck was at 45 degrees. Worked fine at top center and 90 degrees. Made from 304 stainless.
Bubba helped me with making the square end and drilling the 3/8" hole on his mill. Shaft is 5/8" and the handle is 3/8". drove the handle in real tight so no weld required. Kinda purty too.
ID:	147944   Click image for larger version
ID:	147945   Click image for larger version
Woodrow Wilson
Old 10-31-2018, 09:05 PM
Nice. I made a taller one for my lathe at work to for same reason. I also welded a pipe on piece of plate to set on top of the lathe to hold it up too.
Old 10-31-2018, 09:49 PM
Thanks. I have a set of hooks for it just behind the chuck on the wall.
Woodrow Wilson
Old 10-31-2018, 10:15 PM
You should never reach over the chuck on a lathe. The key and other tooling should be accessible without putting your hands in the work zone.
Old 11-01-2018, 07:28 AM
Nice job!!!
Old 11-01-2018, 09:46 AM
I never reach over with the lathe turning.
Woodrow Wilson
Old 11-01-2018, 11:34 AM
never is an absolute it only takes one error. It may not be you using the lathe your grandson is growing up and if so inclined will also use the lathe.
Old 11-02-2018, 02:16 PM
Pic of the lathe chuck key I made for work lathe. And some pics of items I have stored on top of lathe. One before and after cleaning up today. And my folding wrench I made for the qctp.Click image for larger version
ID:	147975Click image for larger version
ID:	147976Click image for larger version
ID:	147977Click image for larger version
ID:	147978Click image for larger version
Old 11-02-2018, 02:17 PM
Magnet mount holder for air hose and chuck key on top of tail stock.Click image for larger version
Old 11-02-2018, 06:14 PM
clive's Avatar
clive clive is offline
A mining company I worked for had a key holder on top of the lathe with a switch in it, you had to put the key in before the lathe would turn on. I guess someone had left the key in the chuck one time.
It's So Easy
