Old 10-25-2018, 03:54 PM
Default Lathe Spider
This spider is for the outboard end of the lathe to hold long small diameter rod from whipping around. Used the lathe index drill jig to drill the holes and start the tapping. Coated with boiled linseed oil for rust protection. Tapped for 1/4-20 allen head screws. I will be changing the screws in the pic because the cover that shuts over the gears has a hole that will not work with the allen head cap screws. Have to use internal screws.
ID:	147838   Click image for larger version
ID:	147839   Click image for larger version
ID:	147840   Click image for larger version
Old 10-25-2018, 07:28 PM
I'm sure that will come in handy at times. It will be good for production feeding.
This made me think of an incident I witnessed several years ago. A man whom I knew fairly well was attempting to turn a piece of 1" diameter aluminum rod. About two feet of rod was sticking out of the outer end of the spindle when he turned on the machine. As some of you might have guessed the spindle speed was set too high for the set-up and the protruding rod was separated from the centrifugal force. The rod had enough energy to tear through a nearby wire mesh gate.
Old 10-26-2018, 09:26 AM
I wanted to build a spider for my lathe a few years back, but I managed to avoid the job. The one time I needed it, I drilled a hole in a potatoe and slid it down the rod and mashed it into the back of the headstock.
I know it's crude.
Old 10-26-2018, 09:39 AM
I know it's crude.
Creative not crude.
Old 10-26-2018, 10:04 AM
I usually jam a rag in around the stock to fill the gap.
Old 10-26-2018, 12:55 PM
...I know it's crude...
Ya think?
Did you at least use and Alberta potato?
It's a sad fact but few lathes actually have any provision on the outboard end of the tailstock for attaching a spider or other device--on a lot of them the stub that protudes is so short that it's hard to attach anything. I made something similar for mine but it is designed to hold a piece of cold finished that is threaded for a 3/8-16 bolt in one end. I use it as a chuck stop when machining multiple pieces of the same length.
For supporting long pieces that stick out the end of the tailstock I've made up a few different bushings out of UHMW that just plug into the end of the tailstock. I should make something like what Chris has but haven't gotten around to it yet. I'd also make it with 4 screws instead of 3--makes it much easier to true something up if you're actually dialing it in. For extreme accuracy gunsmiths will often use 4-point spiders on both ends of the chuck.
A potato? Really? Sighhhhhhh...
Old 10-26-2018, 06:49 PM
Ya think?
What can I say, it worked....besides, I like potatoes
I mean, I could have used a beet, i can't think of any other use for them, and it would be messy.
Old 10-27-2018, 07:25 AM
alchemist's Avatar
I know it's crude.
Wasting food
Just kidding. I have never heard of a spider before. You learn something new everyday.
Old 10-27-2018, 08:49 AM
Haven't built a spider but made a "cat head" like that (4 screws) for the other side of the headstock. :-) I always just used a support and wrapped a piece of cloth or some wire around the stickout to keep it in place. When I've needed to support a long bar it's usually 6 or 8 ft long . :-) Maybe not quite that long. :-)
...lew...
Old 10-27-2018, 12:31 PM
Originally Posted by Lew Hartswick View Post
...Haven't built a spider but made a "cat head" like that (4 screws) for the other side of the headstock...
The terms "spider" and "cathead" are "somewhat" interchangeable but I tend to think of a spider as having 4 screws while a cathead is usually longer and has 8 screws. This allows you to dial a workpiece in very accurately--they're commonly used in gunsmithing applications...
Name:	SA Mandrel 8.jpg
