Old 11-29-2017, 01:26 PM
Originally Posted by Bender View Post
It seems like they build them for about $1500 in labor. Not to mention the NHTSA stamp, although I would certainly overbuild it.
Bender, After having repaired one or two, I realized how right you are. I think Joey has a story or two there also
Old 11-29-2017, 02:12 PM
The wet kit tank holds 40 gallons of oil. I've owned one.
A class 8 truck has the room and frame strength for this.
I was wrong. This one is 50 gal
So what ?
On a small "car hauler" two axle dump trailer, the difference between
a double acting scissor lift, and a single acting "oil hog" multi section
won't amount to much.
Everything in proportion.
And no heavy scissor weldments, bushing & pins to wear out, etc.
The one I provided a linky to, makes the multicylinder with a trunion
mount to be just like the "big boys" mounted vertically at the front.
However, the trunion mount enables it to sit tight to the trailer without
the usual "tee pee" box for the cylinder.
Using qty (2) of them on a 14k gooseneck dump won't consume
much over 10 gallons of oil.
Old 11-29-2017, 02:36 PM
Biggest issue I see with many dump trailers is they are too low. It takes 15' of forward motion to dribble the stuff out the back. I've seen a couple that were built higher, and they worked way better.
The problem I see is trying to make them multi-purpose, keeping them low makes it easier to load equipment etc.
At the end of the day, even when I had a decent dump on my one ton, it's way cheaper to pick up the phone and get it delivered overall.
Old 11-29-2017, 06:38 PM
kbs2244 kbs2244 is offline
The advantage of the scissors lift is that in gives a flat floor all the way to the front wall.
It works fine for somewhat light loads.
But when the weight becomes too much for the friction involved the vote goes to a straight action, centered, telescopic cylinder.
All the gravel carrying semi-trailers are done this way since the load doesn’t care about the wedge-shaped clearance cut into the front floor.
Old 11-29-2017, 08:04 PM
So what ?
I looked at that design again, and I like it better than scissors, because it is double acting and simple to build. Same idea in underground mine trucks, except they have a hump inside for the cylinders. I think you could have a flat floor with a little planning and by making a drop down cylinder mount in front of the tire you could really increase your lift.
Old 11-29-2017, 09:22 PM
I have the drawing around here somewhere but can't find it
(from best metal products, neighbor had a run of them made,
they are semi custom) Unlike the big trucks that simply
mount on the bottom (and require the teepee) the trunion
mount allows the cylinder to "kick out" towards the cab,
but only as it progresses upwards (and is above the cab at this point)
so a teepee is not needed.
Here is another option, for an underside cylinder without
all that steel and machining for a scissor:
http://http://vi.vipr.ebaydesc.com/w...1&secureDesc=0
Old 11-30-2017, 08:24 AM
That last linky no worky.
I had initially dismissed the undercount single cylinder, as well as the front mount multi stage for several reasons. First, that I have built and used several of the scissor hoists and am comfortable with them. Second, cost. Last I looked at a decent size multi stage they were expensive. I had also assumed an under mount single cylinder would have to be a bit longer, pushing up the cost.
I went on to the surplus center site and a 4x36x2 DA ranges from $200-$500. This is much cheaper than I had expected. While a big multi stage runs about the same cost as a scissor lift.
With this unexpected development I am likely to revise my plan and just use a single cylinder. I think this will make the trailer build simpler in the long run.
Old 11-30-2017, 08:52 AM
JohnBoy's Avatar
JohnBoy JohnBoy is offline
Director of Languages
http://ramko.co.uk/tipping-rams/10t-...pping-ram.html
this is what would be used over here, not a big multi stage out front, only see the front mounts on proper trucks with big oil tanks and pto pumps
the one above would be used on smaller ag trailers, or paired for capacity and stabiluty.
Here's some smaller ones, these get used in utility tippers like I linked a few posts up.
http://www.ebay.ie/itm/HYDRAULIC-STA...AAAOSwiLdV9pJV
Old 11-30-2017, 10:02 AM
Take this one, and add a trunion mount and you have what I was describing
(and cannot %$#@! find my drawing/file of it)
If you use 2 of those, the amount of stresses goes down, from 1 concentrated
point, and you can use less bracing underneath, saving precious weight.
It's all about a compromise between keeping the empty weight
down, and maximizing what it will haul.
Old 12-01-2017, 09:04 PM
This trailer appears to be using plain ole cylinders, with no scissor mechanism:
http://www.americantrailerllc.com/tr...-dump-trailers
