Old 01-03-2014, 08:45 AM
SE18 SE18 is offline
Default steel railroad derrick
completed a steel derrick (inside steam boiler and apparatus obviously is wood, coated with marinewest epoxy and later painted)
left it outside to normalize the worked steel and this is what it looks like this morning
it's all welded together and the wheels and pulleys were all turned on my SB9A lathe
(I actually built this derrick to test out my O/A, Marquette Stick, flux core and homebuilt carbon arc welders so all were used in production at various stages; I'm currently building a spot welder so future projects using sheet metal might go even smoother)
ID:	112668   Click image for larger version
Old 01-03-2014, 09:21 AM
Nice project, good for sharpening skills.
I bet you can see all sorts of mistakes but I can see none.
Old 01-03-2014, 11:00 AM
camdigger's Avatar
Roving Reporter
Nice work.
Very representative of the prototypes, IMHO.
Old 01-03-2014, 01:32 PM
brucew's Avatar
brucew brucew is offline
Sorcerer's Apprentice
That's neat!
Old 01-07-2014, 08:53 PM
CEC's Avatar
CEC CEC is offline
Over the Top
That sure looks good. How long did it take to build?
"There is one advantage to having nothing, it never needs repair. " - Frank A. Clark -
