Old 05-17-2013, 04:04 AM
Default The Lug nut impression.
1, 2) Making a key to remove the lug nuts.
3) 3/4" mild steel hex stock, I wanted something harder but that is all I had.
machined down the diameter so I could slide it onto the nut and center it for an impression.
Name:	1a P1010245.JPG
ID:	105596   Click image for larger version
Name:	2a P1010244.JPG
ID:	105597   Click image for larger version
Name:	3a P1010294.JPG
Old 05-17-2013, 04:10 AM
1) Soldering tools.
2) Added a layer of solder.
3) placed it over the lug-nut and hit it with a hammer, did ok but the nut is somewhat rounded and did not quite imprint the outer edges.
4,5 ) roughly cut up to the impression with an 1/8" end-mill.
Name:	1b P1010295.JPG
ID:	105599   Click image for larger version
Name:	2b P1010302.JPG
ID:	105600   Click image for larger version
Name:	3b P1010333.JPG
ID:	105601   Click image for larger version
Name:	4b P1010338.JPG
ID:	105602   Click image for larger version
Name:	5b P1010344.JPG
Old 05-17-2013, 04:14 AM
1, 2) A little tapping with a hammer and finished up with a Dremel.
Wouldn't you know it the nuts were a little tighter then snug, I probably could have unscrew them with a stout screwdriver.
Name:	1c P1010356.JPG
ID:	105604   Click image for larger version
Name:	2c P1010375.JPG
Old 05-17-2013, 04:42 AM
Cavalry's Avatar
Cavalry Cavalry is offline
Below Wholesale
Nice work!
Do you want to reuse the lock or did you just want to get the damn thing off?
These sockets are available for a reasonable price. They work pretty good on stripped lugnuts and lockers
Old 05-17-2013, 07:10 AM
Wow! I'd have just welded a nut onto it.
Old 05-17-2013, 12:22 PM
Originally Posted by Cavalry View Post
Nice work!
One time thing just needed to get them off.
I figured it would take longer to find whatever was used to remove them.
I was thinking about welding a socket on them, was not sure a 120 volt welder would be enough, no 240 volts at the house.
Old 05-17-2013, 01:35 PM
Well, in any case it makes an interesting thread.
Good job, thanks.
Old 05-17-2013, 04:31 PM
Scotts Scotts is offline
Well done young man.
Old 05-18-2013, 05:28 AM
Dave Lee's Avatar
Dave Lee Dave Lee is offline
Armchair Webbie
Well, by golly, that's a new one on me! Good job!
Dave
Old 05-18-2013, 10:57 AM
Floptop's Avatar
Floptop Floptop is offline
That's an impressive impression.
I drive an impact socket tight over the lug nut. Between standard and metric sockets one always drives on tight enough.
