Director of Sarcasm (by appointment) Director of Innuendo (by suggestion) |
Dan if you dont have an answer by morning I will ask my neighbor electrician buddy .
Rick
if it aint broke fix it till it is Proud member of the garbage gang and sub chapter Mole Hill gang ![]() Politically Correct : A term used for whiny pu**ies that need sh*t sugar coated . |
Not saying it's not there but you'll only get 3-phase power if it's actually connected at the pole or meter. Sounds to me like someone may have just used a 4-conductor wire when only 3 were needed. You may find that the blue wire is not hooked to anything at the other end as well...
That blue wire is indeed the conductor for the third phase.
you need to look at the incomming source to see if it has the third phase available. More likely the installer just had a piece of 4 conductor available and the blue is jusr an extra wire in the cable.
Life beats the alternative hands down. |
X2 on use what you got, the blue is most likely safed off at the other end.
Ory-gun Boy! Millermatic 200 w/ SKP-35 Spot Pulse Weld Panel, Tweco MIG-GUN #2, running ER70S-6 .035 wire on CO2, Spoolmatic 1 Spool Gun |
My brother is an electrican. On long underground runs he will use 4 conductor wire instead of 3. The 4th wire will not be connected to anything untill one leg fails underground, at that time the 4th wire will be used and the failed wire is then disconnected. It's cheaper to run 4 conductor than trench in a whole new run. Wires do get skinned or damaged from time to time, crap happens.
The person who said "no guts no glory" is probably dead. There is no such thing as too much ammo.....the real problem is a target deficency. |
Sounds like the thing to do is check it for voltage to see if it's hooked up. Looked on the local craigslist last night, no 3 phase compressors cheap
I checked the blue wire for voltage when I got to work today. Just a spare leg
![]() What's funny is it does show some voltage on it, about 32vac between it and the white neutral. Must have some stray voltage on it I guess. The old thermostat on the old heater was the same way. When it was switched on, it showed line voltage (120vac) but with it off it had about 75vac. So I replaced it. Now when it's off, there's no voltage.
