Old 10-07-2012, 02:26 PM
fluxcore fluxcore is offline
[QUOTE=WinDancer;508172]The motor in my older [maybe 10 years] Delta 10 inch drill press will only work if you start it spinning by hand.
The motor is a sealed unit with no parts available.
It has less that 10 hour total use.
My experience [very limited] tells me that this is a capacitor problem.
Took the motor to a local repair shop, tested the capacitor and it is bad.
The tool repair shop would not sell me a capacitor without a part number.
Delta will not help in any way.
Will anyone give me a capacitor number that I can order to try?
Thanks if it works, oh, well, if it doesn't.
My only option right now is to trash the drill press.
On the capactoor these number on the side buy lose to 5% -/+ will work.,!!!!!! Same size & volts also
Old 10-07-2012, 03:02 PM
Originally Posted by WinDancer View Post
Having the drill press working correctly would save me throwing it out.
Thanks!
Dave
Dave, that would be silly. Hang in there, you'll get your answer.
You just need a start capacitor for a 120v 1/4 hp motor.
They're common as dirt.
I had the same condition with the motor on my old mill. We worked it out in a very short time & solved it for just a few bucks.
Old 10-07-2012, 03:19 PM
rickairmedic's Avatar
SFT HVAC Guru
Well I usually use 5mf caps on Furnace motors that size if that helps any .
Rick
Old 10-07-2012, 04:21 PM
I collect capacitors and when one goes bad I find one that is about the same size physically and put in in and have never had a problem. I know this is not the right way to do it but it works for me. To test a capacitor it is best to have a analog meter set to read ohms, put a lead on each connector and the meter should read high resistance and slowly go to to zero, reverse the leads and the same thing should happen. If it is open it is bad. A digital meter will also work.
Old 10-07-2012, 05:51 PM
MAC702's Avatar
MAC702 MAC702 is offline
set phasers to .50 caliber
...To test a capacitor it is best to have a analog meter set to read ohms...
Well, best would be a digital meter with a capacitance setting. I've tested several that fail, but still provide some amount of steady capacitance, but only 20-50% of what it should be.
Old 10-07-2012, 05:53 PM
MAC702's Avatar
In the air conditioning world, a motor that size could use anywhere from 3 uF - 15 uF, with 5 uF and 7.5 uF being the most common.
Old 10-07-2012, 06:03 PM
Learn something every day. I assumed that the diode checker on a digital was just a continuity check with a bell.
Old 10-07-2012, 06:08 PM
MAC702's Avatar
Diode tester and capacitance tester are two different settings, the latter is more rare, often only found on testers designed for field technicians.
This is mine: http://fieldpiece.com/clamp-meters/sc66
Even my $300 Ideal electrician's digital multimeter doesn't do capacitance.
Old 10-07-2012, 08:25 PM
my fluke 179? does capacitance and it cost me $135. On ebay but with wires and box I'm up to $300.
Old 10-07-2012, 08:35 PM
Lu47Dan's Avatar
Lu47Dan Lu47Dan is offline
Connoisseur of Old Iron
The data I should have included:
The capacitor is unmarked and external under a removable cover:
HP 1/4
V 115
A 32 [Possibly 3.2]
RPM 1720
Lu47Dan:
If he has two [I have two of this model drill press] of them that he thinks will work I would be thrilled to send the money for them and the shipping and a couple bucks for gas. If you have PayPal that would work, if not, snail mail if you send me your mailing address Or I can call him direct and order them, whatever works best for you. And if they end up not working at least we gave it a shot.
Thank you all for the info! Having the drill press working correctly would save me throwing it out.
Thanks!
Dave
Dave, I will call him in the morning and see what he can do, if he can help out, I will send them to you in flat rate envelope.
Dan.
Miller XMT-304 Multiprocess
Miller 10-E Wire Feeder
Hobart AC/DC stick welder
Hobart 175 Mig
Craftsman O/A set
Turbo torch and B-tank
