Old 10-03-2012, 09:40 PM
WinDancer's Avatar
WinDancer WinDancer is offline
Default Capacitor help, please?
The motor in my older [maybe 10 years] Delta 10 inch drill press will only work if you start it spinning by hand.
The motor is a sealed unit with no parts available.
It has less that 10 hour total use.
My experience [very limited] tells me that this is a capacitor problem.
Took the motor to a local repair shop, tested the capacitor and it is bad.
The tool repair shop would not sell me a capacitor without a part number.
Delta will not help in any way.
Will anyone give me a capacitor number that I can order to try?
Thanks if it works, oh, well, if it doesn't.
My only option right now is to trash the drill press.
Wild guesses appreciated!
TIA,
Dave
Dave Evans
http://www.windancerknives.com/
Old 10-03-2012, 09:49 PM
Lu47Dan's Avatar
Lu47Dan Lu47Dan is offline
Connoisseur of Old Iron
Dave need a horsepower rating on the motor to help you out. My local motor shop owner just asks me what horsepower the motor is. He has been doing it for years and knows what rating works for what horsepower.
Dan.
Miller XMT-304 Multiprocess
Miller 10-E Wire Feeder
Hobart AC/DC stick welder
Hobart 175 Mig
Craftsman O/A set
Turbo torch and B-tank
Old 10-03-2012, 09:51 PM
CEC's Avatar
CEC CEC is offline
Over the Top
Dave,
Sounds like a start capacitor.
Internal capacitor or external?
motor hp?
Voltage (120?)
Picture of motor plate?
Picture of capacitor?
This is not a FIX all but a rule, a basic method for motor capacitors.
(2650 x Full load amps ) divided by supply Voltage = MFD
Example 2650 x 8amps = 21200 divided by 240volts = 88.33 MFD
"There is one advantage to having nothing, it never needs repair. " - Frank A. Clark -
Last edited by CEC; 10-03-2012 at 09:58 PM. Reason: Link was for DC not AC... added simple formula that I found
Old 10-04-2012, 08:12 AM
Originally Posted by CEC View Post
Dave,
motor hp?
Voltage (120?)
<This is not a FIX all but a rule, a basic method for motor capacitors.
Example 2650 x 8amps = 21200 divided by 240volts = 88.33 MFD >
Now there is an interesting bit. I'll have to do some "figgurin" and see if I
can come up with the "logic" behind that. ???
If the capacitor in question is "viewable" it may have enough written on it
to determine value.
...lew...
Old 10-04-2012, 08:37 AM
H80N's Avatar
H80N H80N is offline
That Man Behind The Curtain
Lew
It has to do with ELI the ICE man and how much phase shift you need to start a given motor..
Here is a page that may be helpful
http://www.electricneutron.com/elect...acitor-sizing/
Old 10-04-2012, 08:59 AM
H80N's Avatar
TIA,
Dave
Dave
could you give us a model number off the saw?? and any info on the motor data plate??
Model number will allow us to download the owners manual and help figure out motor specifics.. Here..
http://www.mikestools.com/Delta_Dril...s_Manuals.aspx
What if any markings are on the CAP...??
Old 10-04-2012, 09:49 AM
camdigger's Avatar
Roving Reporter
A 10" drill press? Is it big enough to fit a standard frame motor. A drill press has a light enough starting load that a split phase furnace blower motor will work if the bolt holes fit.
My 17" drill press has a split phase motor on it from new. It looks identical to the $75 replacement blower motor I have on the shelf left over from the days I had a furnace it fit.. Sadly, that spare motor won't fit the new mid efficiency range furnace we have now...
Old 10-04-2012, 01:10 PM
TIA,
Dave
I had a 10" Craftsman that puked the cap. At the time, I had a hard time finding a replacement as it was not listed in the parts diagram. I ended up grabbing one from a 10" HF press I had. I gave the HF to a helper who just "helped" it to spin in the correct direction when he needed to use it. Certainly not worthy of "trashing" the unit.
I have a 6" Craftsman bench grinder also with a bad cap. Since it sees little use, I help it spin in the correct direction whenever I need to use it. Spin the wheel, then turn on the power--not really inconvenient at all.
When drilling a lot of holes, I leave my drill presses running to avoid heating up the start caps and causing them to fail...
Old 10-07-2012, 12:42 PM
WinDancer's Avatar
The data I should have included:
The capacitor is unmarked and external under a removable cover:
HP 1/4
V 115
A 32 [Possibly 3.2]
RPM 1720
Lu47Dan:
If he has two [I have two of this model drill press] of them that he thinks will work I would be thrilled to send the money for them and the shipping and a couple bucks for gas. If you have PayPal that would work, if not, snail mail if you send me your mailing address Or I can call him direct and order them, whatever works best for you. And if they end up not working at least we gave it a shot.
Thank you all for the info! Having the drill press working correctly would save me throwing it out.
Thanks!
Dave
Dave Evans
Old 10-07-2012, 02:05 PM
I collect capacitors and when one goes bad I just exchange it with one that is about the same physical size and have never had a problem. I know this isn't the proper way to do things but it has always worked for me. To test a capacitor it is best if you have a analog meter, with the meter set to ohms put one lead on each terminal and the meter should read high resistance and slowly go to zero, reverse the leads and the same thing should happen. If is open it is bad. It can be done with a digital meter too.
