Old 09-11-2009, 07:14 AM
3C welding 3C welding is offline
Shop Floor Talk.
Cutter
Stupid me you know how some of us newbies can be I am catching on thanks for the clue, sorry. By the way thanks for the welcome guys.
lincoln 250 wire matic
millermatic 135 xp
miller Roughneck 2e and 1e
Miller CP 300 w/ 22a feeder
Old 09-11-2009, 07:30 AM
I looked for the K607-1 manual on the Lincoln web site, I did not find it.
Do you have a manual ?
Call Lincoln and ask them to send you all the manuals especially the schematic, tell them you want to repair the one you have.
Not all spoolguns are the same, what's the make ?
Some of these box's are just cheap power supply's.
I have searched all over lincolns non user friendly site aswell and got nothing out of it. I google search a million combinations and found a manual for the K607-1 but it did not have the details i need to try to put one togather, however it had part numbers and I thought might chase the important parts down that way. The only thing in the k607-1 that i am not sure about is a P.C. board according to the manual I found it has one in it. I have not purchased a spoolgun yet until I knew if I could make it work. If a cheap power supply is what I have to get than I will if it will hold up and work.
millermatic 135 xp
Old 09-13-2009, 04:23 PM
I cant help you without seeing what you have on the k607-1
Manual IM-453-A.
Assuming I looked at the right manual, the Wire matic 250 manual does not say anything about using the k607-1.
Or did I miss it ?
Why do you think you need the k607-1.
Old 09-14-2009, 09:15 AM
The following link takes you to a setup that would probably work for you.sga100 and 3035 spooler I have also seen a Spoolmatic 1 spoolgun with controller for a few hundred bucks, also. That could be a lower cost alternative.
But if you have the patience, keep combing Ebay and craigslist for the "right" unit or compatible unit--you might find what you're looking for for cheap.
Dea at JustArc could probably help you with an adapter but they can be pricey...
The expression "throwing good money after bad" comes to mind. Some of the old iron just can't do what you want it to do and by the time you buy adapters and controllers and the time you spend, you could have bought something turn-key and spent the time earning money to pay for it. Christmas/Chaunukah/Qwanzaa are coming soon so that could be an option...
Old 09-14-2009, 09:23 AM
That is the right manual, over the weekend I did some more homework on it and saw the same thing no k607 insight. The reason I was looking for it was because my dealer here told me originally that I would need it for the new spool guns to hook up (I think he is lost). According to my manual It says the k487 gun should just hook up with no adapters. It also shows that the machine has an on board spool gun module, which I missed the first time I read through it. Pages 11-12. I will varify the machine this evening when I get home.
Thanks for helping I will update soon.
Maybe this will solve this thread
millermatic 135 xp
Old 09-15-2009, 08:09 AM
I have looked at this option because I also have a toy welder 135xp it would work on but I was not sure about it in combination with the linconln and Dea has been very helpful those far. For the money that I have in the machince it may be more cost affective to trade up and go back to a blue machine ready to run a spool gun you know. I have plenty of time to keep looking for a control box and gun if anyone has a good buy out there.
millermatic 135 xp
Old 09-15-2009, 08:13 AM
This is all false wrong machine I called lincoln and everything still goes back to the k607-1 adapter.
millermatic 135 xp
Old 09-15-2009, 08:55 PM
Barn Owl's Avatar
Barn Owl Barn Owl is offline
I am not sure about Lincoln spool guns but I just bought a brand new Spoolmatic Miller spool gun and it did not come with the adapter to run it from a multi purpose XMT304. "You needed to purchase an adapter" is what the sales guy said. so $245 later I am the proud owner of a $25 transformer that chokes 110 volts down to 24 volts. It is all propietary so you cannot just go to the local electronics store and get it cheap. If it is really hard to find your part, it might not be that difficult to adapt it yourself IFyou know what you are doing. The pin connectors will be the hardest to find and solder up.
Mike
Thomas Jefferson
Old 09-16-2009, 08:51 AM
After extensive, deligent and much patience I have found what I believe is the last remaining K607-1 adapter kit in the world. The instructions in the kit verify that it goes to my machine and everything fits right up. Weldsource.com is where I found it for 251 dollars. So now I am in the market for a reasonable Ck systematic, snap on, or lincoln magnum spool gun they are all the same and are made by Ck systematic.
Thanks
millermatic 135 xp
