Old 09-08-2009, 01:57 PM
ace4059 ace4059 is offline
Tender Member
Default Buy it or make it? (14 pin cord)
New 14 pin cord is about $200 for 50 ft. I bought a used 50 footer for $70. It is a Miller cord and it is just 18/6 SOOW cord and it has the "special" 14 pin connectors.
I was wanting another 14 pin cord (but shorter, ~25 foot), but I think Miller is proud of these. I was wondering if I could make one cheaper. The problem I have come into is I cant find the 14 pin male or female connectors.
I did find this one
http://images.google.com/imgres?imgu...%3D60%26um%3D1
scroll about 1/2 way down to see it.
I was told only one place has these 14 pin connectors and you have to buy them in bulk. So does any one else know where I could get some at?
Lincoln Pt 225
Lincoln PM 215
Lincoln Buzz Box
Hypertherm 600
HH125 EZ
MM 350P
TB 302
Calling an illegal alien an "undocumented immigrant" is like calling a drug dealer an unlicensed pharmacist.
Old 09-08-2009, 02:06 PM
Paychk's Avatar
Paychk Paychk is offline
Project Phoenix
The bare connector can be bought through Miller, I used to have the P/N, I'll see if I can find it.
male connector Miller P/N 141162 : http://www.gts-welco.com/gtsweldssto...l.aspx?ID=1360
female connector Miller P/N 152369 : http://www.gts-welco.com/gtsweldssto...l.aspx?ID=1361
Ory-gun Boy!
Old 09-08-2009, 03:46 PM
Cavalry's Avatar
Cavalry Cavalry is offline
Below Wholesale
If that does not work I check into shells mfg by AMP, available though Newark
Old 09-08-2009, 04:00 PM
Try this page.
http://www.youngssurplus.com/electri...re%20cable.htm
Old 09-08-2009, 10:13 PM
Tender Member
Default The Verdict is...
It is cheaper to the cord already made from Miller. There is a NEW 25 foot cord on ebay right now (I think it is from B&R welding supply) and it is on sale for $110 (regular price $175).
The male connector and female connector are $45 each. So 90 bucks plus shipping and I would still have to buy the 18/6 SOOW cord. That SOOW cord would be about $1 per foot. Then I would still have to put it together.
Thanks paychk for the part numbers.
-Ryan
Lincoln Pt 225
Lincoln PM 215
Lincoln Buzz Box
Hypertherm 600
HH125 EZ
MM 350P
TB 302
Old 09-15-2009, 01:07 AM
Tender Member
On this 14 pin cord that I bought It turns out it is just one of those deals where it is "just my luck". The cord only has 6 pins and the one I need has 8 pins. The G and F slots are empty so my suit case feeder doesn't display the volts or amps. The cord still works and the feeder works just fine but I have to look back at the welder to see the volts instead of the feeder. Just my luck. I guess I will have to buy a new 14 pin cord.
Lincoln Pt 225
Lincoln PM 215
Lincoln Buzz Box
Hypertherm 600
HH125 EZ
MM 350P
TB 302
Old 09-15-2009, 02:55 PM
rmack898's Avatar
rmack898 rmack898 is offline
That HURT!
I needed a 2' cord for a special project I was working on and bought the connectors and cable here http://www.ssccontrols.com/homepage-weldingcables.htm They also gave me the part #s so I could order them direct from Allied.com where they get the connectors. The part #s are 605-8699 for the plug and 605-6698 for the socket. They are standard Amphenol plugs and cost about $28 each.
Mac
Old 09-15-2009, 06:58 PM
I bought a rotory amp control from CKworldwide and it came with a nice die cast alum one.
I guess the reason I'm even posting this is the plastic ones always feel cheeze to me. This one has a nice feel to it.
These type of connectors are also used by the military.
Old 09-16-2009, 11:03 AM
Just an FYI the web site is http://www.alliedelec.com/
