Old 08-26-2009, 11:31 PM
David Lutz David Lutz is offline
Default Bobcat Question
A friend of mine has a Bobcat 225G that has two 240v 15 amp outlets on the front panel. He also has a custom made "Y" pigtail that plugs into both outlets and has a 240v 30 amp outlet on the other end. Is this safe to use to run a Hobart 187 if I change the 30 amp outlet to one that matches the Hobart NEMA 6-50 plug?
He said someone made the "Y" pigtail in order to power a floor waxer or something. He wasn't exactly sure and he said he never used it himself. I don't want to plug it in if it's not a good idea. I don't want to fry my Hobart and I really don't want to do anything to hurt his Bobcat.
Thanks in advance.
ID:	50144   Click image for larger version
ID:	50145   Click image for larger version
ID:	50146   Click image for larger version
Old 08-26-2009, 11:52 PM
Barn Owl's Avatar
Barn Owl Barn Owl is offline
The electricity doesn't follow road signs, It does not know that half the amp draw should go through one plug and the other 15 amps should go through the other, especially when it is "wyed" the way it is. 240 is 240, if the draw gets over 15 it will most likely just pop the breaker on the bobcat. This is as long as the two 240 volt outlets are from the same circuit, which it appears they are. If it is coming from two different circuits then throw that pig tail away, you will blow up your welder. Check the voltage at the 30 amp plug first.
Anyway you look at it is less than optimum and sketchy at best.
Mike
Thomas Jefferson
Old 08-27-2009, 06:50 AM
moe1942's Avatar
moe1942 moe1942 is offline
Voice of Experience
Have your camera ready when he tries that..Post them in shop safety...
Old 08-27-2009, 08:13 AM
Davidk4x4 Davidk4x4 is offline
The real danger is when only one side of the pigtail is plugged into a 240 volt 15 amp receptacle, the other male plug is HOT... do I need to say more
David
Old 08-27-2009, 10:31 AM
Ok, thanks for the feedback. I'll tell him to get rid of the pigtail just in case anyone else considers using it. I'd rather not be posting graphic photos in the Shop Safety forum.
Old 08-27-2009, 11:57 AM
moe1942's Avatar
Voice of Experience
David I have the old style BC like he has. The later ser# have a single 240 V 35A outlet. There is a total of 30 amps available on ours using both outlets but not knowing how it's wired I would vote no on the pigtail. Dealing with tricity I always err on the side of caution.
Having said that you could get 30 amps on one outlet if the receptacle and wiring were heavy enough. The Bobus has an 8500 watt rating..
Old 08-27-2009, 03:28 PM
Thanks for the info Moe. I think Barn Owl nailed it pretty good when he said "sketchy at best." I wish my friend had the other model. It'd be really nice to have a remote option for my Hobart.
I guess I better learn to stick weld after all. I'll start another post with photos of my frankenstein welds. I'm going to try to post more to keep OM happy.
