Old 05-24-2016, 07:25 PM
allessence's Avatar
Gadget Girl
Default Log pull spike
Well I had a guy come by the other day with a job to make a log pull spike.. Time 1hr 30min.
The drawing he did was good but the design was off..
Most log pull spikes are pretty short.. Turns out he wanted on with a shank about 10" long.. Way to long to be useful, but..
So today I pulled out a bar of 3/4" hot rolled and started wailing on this thing.. The end product though good was made from mild steel as requested.. (I am shaking my head as I just typed that)..
The end of the bar was upset for about 3" of length to about 1.250.. Then the upset is offset on the bar..
The end was set for a striking end, and the side was drawn out with the cross pein hammer on the face of the anvil just over the table..
ID:	132116   Click image for larger version
ID:	132117   Click image for larger version
ID:	132118   Click image for larger version
ID:	132119   Click image for larger version
_________________
Jennifer
My google+ page
DoALL 36"
Old 05-24-2016, 07:31 PM
allessence's Avatar
Gadget Girl
The spread out end is then offset and the end forged down for the striking end.. This offset side piece was then drawn out with the pein again..
This operation is much simplified with a good striker..
Luckily having the big HB anvil in the trailer made it doable in a timely fashion.. Working a large section on the 175HB on the light stand with the bouncy floor was brutal..
ID:	132121   Click image for larger version
ID:	132122   Click image for larger version
ID:	132123   Click image for larger version
ID:	132124   Click image for larger version
_________________
Jennifer
My google+ page
DoALL 36"
Old 05-24-2016, 07:40 PM
allessence's Avatar
Gadget Girl
Here it is..
I did test it and the tip bent a little with some extra weight on it..
I may have to adjust the point geometry tomorrow..
This is the typical type item where a medium carbon steel would have been perfect..
ID:	132126   Click image for larger version
ID:	132127   Click image for larger version
_________________
Jennifer
My google+ page
DoALL 36"
Old 05-24-2016, 08:29 PM
This is for dragging a log?
Old 05-24-2016, 09:05 PM
CEC's Avatar
CEC CEC is offline
Over the Top
Nice work...
Like Chris said... This is for dragging logs?
"There is one advantage to having nothing, it never needs repair. " - Frank A. Clark -
Old 05-24-2016, 09:07 PM
SmokinDodge's Avatar
Jen I'm not smart enough to figure out how it works. Can you show a pic of it rigged?
Sent from my ipotato
Old 05-24-2016, 09:17 PM
look at bottom of 4th pic . Has description of being used to roll the log. Sounds like a lot of work.
Old 05-24-2016, 09:28 PM
Your right it says to roll a log. She did say it was not her design and it did not work too well. Makes me wonder why the guy does not use a log roller???
Name:	Log Roller.jpg
Old 05-24-2016, 09:39 PM
look at bottom of 4th pic . Has description of being used to roll the log. Sounds like a lot of work. Brian
Ah. As I said not very bright.
Seems like a job for a cant hook or peavey but who the hell am I to cut Jen out of work?
Old 05-24-2016, 10:16 PM
Around here when you talk about log spikes or boom spikes you're referring to something like what is shown in the picture. They're driven into a floating log and used to tow it--log salvage and beachcomber guys use them a lot. They're not strong enough to yard logs off a beach or to tie a boom together although they can be used temporarily when making booms up.
Cant hooks and peaveys are almost identical; cant hooks have blunt ends while peaveys have spikes on the end. The pic that Chris posted shows a cant hook. Cant hooks tend to be used more on small logs while a peavey is for heavier stuff where you can't wrap the hook around the log and need to use the spike to get some leverage....
Name:	Log Spike.jpg
