Old 11-12-2020, 06:29 PM
Yes indeed. Without a scale to go by but I'd guess about 360 mmf . :-) Now you're into stuff I grew up with and worked with for 20 years . Note! the description I used. Long before the advent of "pico" made the scene. :-)
...lew...
Old 11-12-2020, 08:39 PM
...lew...
I knew that item would get your attention, Lew!
What is "mmf": micromicrofarad?
TA 95 lunchbox w/tig
Old 11-12-2020, 09:57 PM
Scotts Scotts is offline
If you got it to run on ac it most likely works like a hand drill motor those will run on 120 ac or dc.
Time to raid the used drill pile for a variable speed trigger and you would be well on your way to the weld positioner easy peasy
Then you could have your other part for something else.
Old 11-13-2020, 08:23 AM
I agree and you both win but if it looks like a duck I'm going to call it a duck...
Calling a Variable Transformer other than a Variac is just going to confuse people, so call this Duck a Variac and if you want a specific manufacture then call it out with Variac.
Variac is an adopted name like
Allen wrench = hex keys
Crescent wrench = adjustable wrench
Channel locks = water pump pliers...................
Old 11-13-2020, 08:37 AM
pulled these pictures from the net.
1) the box implies Permanent magnet motor
2) DC gear motor, 90 volts, 0.83 amps
two wire motor
ID:	158468   Click image for larger version
