Old 10-30-2020, 12:04 AM
Cutting the key way. I cobbled together a bracket and a U bolt to secure the shaft.
I installed the motor on my compressor. The next sandblasting job will be coming soon. I get to try out my new to me Lindsay 200 sandblaster then as well.
Old 10-30-2020, 11:34 AM
Originally Posted by seagiant View Post
Hi,
Looks good, I would not of done it that way, but...
I would of machined a step on the shaft stub and then a peice of steel to fit that, with just enough room to pre solder (tin?) those together...
Then would of drilled a 1/8" inch hole through the middle and peened a peice of drill rod to mechanically lock it.
That would of kept the heat down, protecting the bearings and the new shaft would be auto aligned, so to speak!
I would have seriously considered this if I gave you chance to respond before I started.
However, I question my ability to solder this fast enough so as not to allow too much heat into the shaft. I can see myself spending a minute or more getting the solder to flow.
In contrast the MIG welding is very fast. I feel I have much more control over the heat input. If it is getting too hot I can stop, cant do that with soldering.
