Old 11-08-2020, 03:00 AM
I did this to mine on the Quincy build, and put in a delay relay set for 10 seconds to keep the valves lifted till the motor is up to speed and oil is distributed.Then it starts pumping.
That has been a great idea for sub zero cold starts, no popped breakers, no slipping belts.
My Quincy pump has a feature that provides the same affect. It was an option at the time when I ordered it. As I recall it is called an unloder.
Old 11-09-2020, 11:59 AM
Nicely made box, however, I would have mounted it on the wall, to help
keep it away from vibrations.
Old 11-09-2020, 05:31 PM
platypus20's Avatar
Boiler God
I hate remote panels, I want the controls mounted directly to the equipment, IMO if vibration is that much of a concern, then fix the cause of the vibration
jack
Old 11-09-2020, 05:58 PM
They have an unloader which is switched on when the oil pressure comes up. I put in a solenoid controlled by a delay relay I set for 10 seconds.
