  #1981
Old 11-01-2023, 08:10 AM
I like the idea of the remote power feed.
and having a removeable roof is excellent.
or at the very least you can put a hatch in the roof,12x12'' or so,just big enough to drop a cable through and pull the pump out.
did they use plastic drop pipe to the pump?
if so,the hatch may not work so well?
That's a lot of work to do when a pitless adapter solves all your concerns. No building needed, no electric heater, easy access to the well to change pumps and less cost.
Which is why I did it that way.
Name:	Pitless Adapter.jpg
  #1982
Old 11-01-2023, 07:01 PM
OldRedFord's Avatar
Kibble King
Time to get started on that well house.
Tim
  #1983
Old 11-02-2023, 06:57 AM
randydupree's Avatar
Why, Hell Yes!
I have seen those in the north,but in my area i have never seen anyone use them.
I have no idea why.
  #1984
Old 11-02-2023, 06:58 AM
Why, Hell Yes!
Yep,cold weather is coming.
41 here yesterday at 6am,i have not been out yet today,supposed to be in the 30's.
  #1985
Old 11-02-2023, 07:40 AM
I have no idea why.
I guess they like to spend money.
In a lot of cases it isn't what makes sense, it's do what the rest of them do. Although a homeowner like me, with a measuring tape, drill, and hole saw, can install this system, people call a contractor. Now, he's never even heard of this, and his first words are "That'll never work"
  #1986
Old 11-06-2023, 08:07 PM
OldRedFord's Avatar
Kibble King
Started on the well house yesterday. It's 4x6 feet and 4' high.
Corners are 4x4 posts in concrete. Exterior will be lap siding. Tin roof.
ID:	169354   Click image for larger version
ID:	169355   Click image for larger version
ID:	169356   Click image for larger version
Tim
  #1987
Old 11-06-2023, 08:12 PM
OldRedFord's Avatar
Kibble King
I pulled a 20 amp 120v circuit to the well house from the main panel. In the well house it's feeding an outlet and then two light switches. One light will be a heat lamp. The other a plan bulb. Figure if the pressure switch ever went bad it'll probably at night after dark.
ID:	169358   Click image for larger version
Tim
  #1988
Old 11-06-2023, 08:24 PM
While your running wire, run a line out from the pump switch to an outside light. This will let you know the pump is running. very handy to know if the pump is cycling correctly or running continuously.
  #1989
Old 11-12-2023, 07:17 PM
OldRedFord's Avatar
Kibble King
Far as I'm concerned this is ready for inspection.
ID:	169415   Click image for larger version
ID:	169416   Click image for larger version
ID:	169417   Click image for larger version
ID:	169418   Click image for larger version
Tim
  #1990
Old 11-25-2023, 11:20 PM
OldRedFord's Avatar
Kibble King
Welp I found a problem.
Decided to run the shower the other day. It's not supposed to shower in the wall.
https://www.tiktok.com/t/ZT8fjtv6L/
https://www.tiktok.com/t/ZT8f61LM6/
Tim
