  #1491
Old 08-02-2021, 01:34 PM
You got a pet!
  #1492
Old 08-02-2021, 02:09 PM
Shop mascot!
  #1493
Old 08-02-2021, 06:46 PM
OldRedFord's Avatar
Kibble King
I was reminded of youtuber Steve Summers and his squirrel
Hung some sheetrock today. Started at the bottom because it's easier that way alone. Also have a soffit to build out at the roof line.
ID:	161197   Click image for larger version
ID:	161198   Click image for larger version
Tim
  #1494
Old 08-02-2021, 09:17 PM
Rocky Racoon
  #1495
Old 08-02-2021, 09:33 PM
Originally Posted by slip knot View Post
Rocky Racoon
My old boss had a pet raccoon that he rescued when it was a baby. It’s name was Rocky.
  #1496
Old 08-04-2021, 07:27 PM
OldRedFord's Avatar
Kibble King
More progress today. The gap is where im going to add a post to stiffen the wall. I cut the sheets in half because it's way easier to handle ten feet up by myself.
ID:	161230   Click image for larger version
ID:	161231   Click image for larger version
Tim
  #1497
Old 08-11-2021, 03:01 PM
4-13-1949 to 5-21-2023
No sheetrock lift?
LET'S GO BRANDON!!!!
B biggest
I idot
D democrats
E ever
N nominated
  #1498
Old 08-11-2021, 06:33 PM
No sheetrock lift?
The cost of mudding the extra joints would easily cover buying a panel lift.
  #1499
Old 08-15-2021, 06:15 PM
OldRedFord's Avatar
Kibble King
I do have a sheetrock lift somewhere. I just don't remember where tgat somewhere is. Also it only goes up eleven feet.
If of used a lift but im working backwards starting at the floor and going up. I have a soffit to build out at the top of the wall but im holding off on that till cooler weather. Yes it's a little extra work on this wall but sure is easy by myself.
Framed out the other corner and mounted some outlet boxes this afternoon..
ID:	161293   Click image for larger version
ID:	161294   Click image for larger version
Tim
  #1500
Old 08-16-2021, 06:14 AM
Often those lifts can be ‘extended’ by adding a section between the frame foe the sheet, and the mast. IIRC a piece if pipe and some steel rod the right sizes should do what you need.
It does make it higher to load the sheet, but heck, you have a forklift too.
