#71
The other time I’m not sure the cause, I don’t recall hearing if they figured it out. It was a larger wet grinder, with a wheel that was I believe 2” wide and 12” diameter. For those that don’t know, when ever coolant is used on a grinder, shut the coolant off, and run the wheel for another few minutes. (Was always told two minutes minimum, I tried to go 5-10 while doing other things.) This allows the water/coolant to fling back out, or off the wheel. If not, the liquid can settle to the ‘bottom’ when shut off, and can cause an out of balance situation. Sometimes enough the wheel can crack and explode. Oh, and Tim, if no-one has shown or told you, make sure to ‘ring’ a wheel before mounting it. Balance it on your finger or whatever is easy, and give it a light tap with something non-metallic (plastic screwdriver handle, for example), and a good wheel will ‘ring’. If it’s cracked you will hear a dull sound or even a thud. If that’s the case, destroy and toss it. Sent from my iPhone using Tapatalk |
#72
I was running a (IIRC) Landis hydraulic grinder, about 60 years ago. The mag vice was a big DC powered vice, with the power supply on the wall next to the machine. The wheel was about 1.5x12. The project was precision drill press vice bodies. It got real exciting when the power went off. The vice body, some how, cleared the guard at the end of the table and bounced off the wall. There wasn't much left of the wheel. At the time I didn't think it bothered me that much. However, when everything was reset, and the wheel took it's first pass, I about hid under the machine. It took a while to get over that excitement. The chuck was replaced with a permanent magnet chuck real soon.
Make over, make do, or do without Why do I have to press one for English when you're just gonna transfer me to someone I can't understand anyway? Grant me the strength to accept the things I cannot change, the courage to change the things I can & the friends to post my bail when I finally snap! |
#73
Did a quick scroll thru the video, so, this machine needs a new screw for the cross slide?
At the rate you’re going you need to retire now to have the time to do the projects you already have. How long til we hear about ORF needing time to relax again due to impending burnout? Sent from my iPhone using Tapatalk |
#74
Getting bored? Yes. Burnt out? No. It does need a new cross feed screw. The part the arbor is mounted in moves forward and back. Table only side to side. Already have the broken screw removed. Now im looking for a 10 tpi acme thread carbide cutter and a matching holder.
Tim Self appointed director of junk, and old vehicles. |
#75
Now im looking for a 10 tpi acme thread carbide cutter and a matching holder.[/QUOTE]
ORF, Why go to the expense of a carbide cutter for a one off job? You won’t be running it at high speed when you do the screw cutting, a hand ground HSS tool will do the job fine. Sent from my iPhone using Tapatalk |
#76
ORF, Why go to the expense of a carbide cutter for a one off job? You won’t be running it at high speed when you do the screw cutting, a hand ground HSS tool will do the job fine. Sent from my iPhone using Tapatalk[/QUOTE] True, but all the cool kids use Carbide...... Seriously, with all the grinders ORF has, a simple profile gage - even one cut from a cereal box, and 10$ worth of HSS would do all the acme threading ORF would do in his lifetime. And he'd learn a new skill....
Design to 0.001", measure to 1/32", cut with an axe, grind to fit.. |
#77
There is a time and place for HSS, and this is one of them.
The price for the holder for the carbide acme thread tool would be impressive.
Gerry You got freedom of speech, if you don't say too much. Aaron Neville. When a liberal screams racism, you can bet they were also born with white skin. Common sense is like deodorant. The people that need it most never use it. Joe Concha |
#78
+1. Unless you plan on manufacturing them for others. Heck, if you really want carbide, just get some 1/2” square brazed carbide cutting tools and grind your own. Sent from my iPhone using Tapatalk
#79
Or, buy a length of acme threaded rod and just machine ends to suit.
#80
That was my thoughts at the start of the lead screw discussion. I expect he has plenty of other things to do beside making your own.
