Old 03-23-2020, 07:54 PM
Perhaps, just working with what I was given though. These are parts for a subcontractor in the area, that occasionally does repair/welding work for another company. He knows I have the mill/lathe, and passed it along to me.
I’ll put a value on it, then trade it for materials for future projects of mine. Makes for a paperless deal that works for both of us.
Old 03-23-2020, 08:58 PM
JBFab JBFab is offline
You're bringing back terrible memories! I have installed thousands of those damn things. Lol
So, I have a little job in the shop, that, to make things work, we are adapting ‘elevator bolts’ to work. They are basically a flathead bolt, with a square under the head, like a carriage bolt. They are made for bolting scoops to rubber belting for grain elevators and similar soft materials.
Attachment 155253
Old 03-24-2020, 05:45 AM
Nice custom tooling. Will have to file that one away just in case.
Old 03-24-2020, 06:46 AM
Nice job!!!! Ya know I have never silver soldered anything
Old 03-24-2020, 10:26 AM
Default Custom countersink
Fairly easy to do. Just remember if it’s something that spins, aim for the centreline, and have relief. If it’s on a lathe then the toolholder will allow the adjustment for centreline.
Old 03-24-2020, 10:31 AM
Basically the same as soldering copper pipe. Clean it, add flux, heat til the solder flows, and let cool. Because of the carbide, just let it air cool until you can touch it, then I’ll run it under hot tap water to wash the hardened flux residue off.
Silver solder comes in various alloys and forms (wire of various diameters, ribbon, sheet etc.)
I just use whatever pieces I have in my toolbox from previous jobs.
The flux is cheap, it’s a paste. It has a tendency to go hard/dry over time, add water and remix it and good to go.
Old 03-24-2020, 11:03 AM
Are these bolts to attach buckets on a vertical belt?
Old 03-24-2020, 12:06 PM
https://www.carbideanddiamondtooling...2-_p_1112.html
Old 03-24-2020, 02:13 PM
From what I understand that is the normal use. These were being used to replace a knurled, pressed in stud on thin aluminum. Sorry I can’t post a pic of the actual bolt in use.
Old 03-24-2020, 02:17 PM
I’d never seen an adjustable countersink until you posted that, good to know.
This job may or may not be a repeat thing, if it is, I have the tool already. If not, maybe someday I’ll modify it for something else. For a couple hours of ‘social distancing’ and basically zero cost, it was a fun little tool to make.
I have a few other tools I’ve made over the years, I’ll see if I can get some pics later today.
