Old 03-19-2020, 06:55 PM
Default Need help with parts alignment
I need to make 4 of these brackets. They hold stanchions for cable railing. The round portion is 1.5" pipe. The flanges are 3/8" plate with an ellipse cut in it. After fitting the pieces together there is about 20* rotational play.
I use a Flange Wizard for fitting the angles. I usually just punch the top to keep it in the same orientation in the band saw.
I just can't noodle out how to punch/mark the parts for alignment and alignment is fairly critical. I can mark centerline of the plates without problem.
Any ideas?Click image for larger version
Old 03-19-2020, 07:19 PM
I don't know if this will help but use a piece of angle and scribe a straight line then tack the pipe to a piece of channel then to the saw
Old 03-19-2020, 07:51 PM
Any ideas?Attachment 155193
I'm not sure what you are asking do you have a drawing you can post?
Old 03-19-2020, 08:15 PM
If you are trying to mark the centerline with the high/ low of the pipe angle, hold the pipe against a 90 degree square plate, and then I used to use an adjustable machinist parallel set to 1/2 the diameter of the pipe and then scratch the center lines on the pipe. Then you can use these to line up your brackets.
Hope that made sense.
Quick hand drawing
Old 03-19-2020, 09:01 PM
Ironman Ironman is online now
I would line them up when you draw them in the plasma program. On two opposing sides of the disk, draw a slot 1/8" deep and 1/16" wide into the outer edge with the plasma. When you hit burn, they will have identical slots to slip a bit of stock into for lineup.
You can weld the slots closed after if it offends.
Old 03-20-2020, 12:57 AM
Or tilt the flange at an Angle and cut the hole
then
Cut the ellipse/oval on the plasma cutter.
Name:	Angle drill.jpg
Old 03-20-2020, 05:40 AM
I am remembering other things I used to do when I was making pipe handrails for a main job.
I tried another Amish drawing to get my idea across. This was helpful especially when I had to do angle cuts on both ends of the pipe. I would cut one end, put it in the bench in the layout jig, and then could scribe mark the other end and use those marks to line up in the saw.
Old 03-20-2020, 05:50 AM
That stanchion fits into that pipe. If the pipe is rotated either way before it is welded then the stanchion won’t be vertical.
You have given me ideas though. FirstI mark the centerline through the plate by marking either end with a point while cutting, then just scribe the centerline. Then mark the centerline of the pipe on the high and low side of the pipe, which would be the two sides while in the bandsaw, by scribing a line down each side before cutting. Then after the angles are cut I can simply line up the scribed lines.
When I get back out there tomorrow I will take some pics, unless it doesn’t work out, then I’ll delete this post!
Old 03-20-2020, 09:10 AM
JBFab JBFab is offline
Please forgive the VERY crude sketch, but I would make a quick jig to hold the parts in alignment with some scrap flat bar.
Because your pipe is at an angle, two parallel flat bars will hold it from being able to rotate (as long as you hold the angled cut to the table/base plate).
The base plate itself could probably be eyeballed - probably better that way actually.
Old 03-20-2020, 09:13 AM
Crude my a$$. That beats mine hands down.. At least it gets your idea across, and helps Andy figure out how he wants to do it for his current project.
