Old 03-18-2020, 04:01 PM
digr digr is online now
Default Ford door hinge pins
Anyone need to change the ford F series or Bronco truck door hinge pins if so I have the tool for you that I made for repair on old 95 F 250 I believe the pins are the same from 89 to 97 and maybe latter years. I am sure I will never use again so if anyone by chance needs it I can mail it to you. It saves a lot of time especially on the lower hinge that has to be done on the truck. I didn't remove the door. I got to use the hex collet block I made to put the hex on it.
ID:	155187   Click image for larger version
Old 03-19-2020, 08:42 AM
Windy_Acres's Avatar
Chairman of the Headboard
1980 to 1997-1998.
Nicely done !
Old 03-19-2020, 09:59 AM
Twice the size--half the man
Not sure exactly how this works, but I'm game to give it a go and pass it along to whoever else needs it!
I went out and looked to try and get a better idea what I'm up against, but I've needed to replace the ones in my '92 Bronco for a long while.
Wade's Custom Kydex
Old 03-19-2020, 10:59 AM
What I did was to use blocking and a jack to support the door when it is opened all the way then starting with the bottom hinge------
1 Use a die grinder to grind off the top of the pin and drive it out
2 Unbolt the hinge from the door and rotate it and remove it, you might
have to raise the door to get it out
3 Use the tool to remove and install the new bushings (the lower bushings
are installed on the hinge bracket bolted to the body)
4 Bolt the hinge back on the door and install the new pin. The new pin is
knurled and is very hard to get it to seat in the hinge plate ( I wouldn't
try to get them seated until both new pins are in)
5 The same goes for the top hinge only the hinge bolted to the door has
the bushings. ( there are stops on the top hinge and if you get them in
the wrong spot you won't be able to bolt the hinge back on the door)
PM me your address and I will send it to you
Old 03-20-2020, 09:54 AM
old 95 F 250 ….. I am sure I will never use again so if anyone by chance needs it I can mail it to you.
Is 1995 old? My newest vehicle is 16 years older! (my oldest is 77 years older)
You have given me a great idea. For some time I have been concerned about what will happen to my "special" tooling and such when I no longer need it. I dread the thought it may go to scrap if someone could use it. I can use forums like this to give them to the right fellows. I should start soon.
