Old 03-21-2020, 01:30 PM
Shoot, I guess I can’t be an efficient machinist after all. 98% of my threading is single point tooling. But then again, most of my threading is one of a part over 1” diameter too. Usually anything smaller I try to use a tap. On od threads I do all the way down to 1/4”.
Of course there was that one time I made a 4-40 screw to hold the end of my Starrette RPM counter in. I figured if my threading inserts say they can cut from 8TPI to 48 TPI, I should be good to go. Almost needed a magnifying glass to see it though.
I'm sure I am not either, but for smaller rod stock I do use a threading die in the lathe.
I want to see Keith use a 1" pipe tap to thread a hole in the lathe
I might learn something. So far, I learned that it was a stupid idea, but had to be done. So I roughed out the thread with a boring bar and single point, and finished it off with the tap, lowest gear in the lathe, and turn til stall, reverse, lube turn til stall, repeat.
I can't remember how I acquired that 1" NPT tap, but after that job I threw it in the scrap....and then fished it out a day later because some guy told me you could drive it with a 3/4" impact wrench.
We shall see.
Old 03-21-2020, 01:49 PM
We shall see.
I have a several taps over 1”, and I usually can’t hold the chrome plated rod tight enough to keep it from turning in the chuck, and then fear scratching the chrome. That is highly frowned upon when seals have to go over it.
Sometimes I will rough out most of the thread and then use the tap to finish.
Old 03-21-2020, 02:10 PM
Pretty common practice for one off’s over the years to single point the bulk of it, then run a die over it to finish. Keeps things straight, but about as quick as possible.
At the plastics place we had taps up to about 3”, I know we had a 5’ long tap handle for some of the bigger stuff, and more than once we’d have pipes on each end with two guys turning it.
Old 03-22-2020, 08:32 AM
That's ugly. Naw, they aren't WWF stars, that's the tapping crew
