Old 03-05-2020, 10:48 AM
Default Engine Oil, Reading the Label.
This is nice short video. If you are running a stock engine, this is all you need to know.
https://youtu.be/bBRpcD3Y93s
Old 03-05-2020, 12:23 PM
Since that video was 5 years old, is the current spec still SN?
For 2020 cars?
And are all oils usually backwards compatible? If I am using a 2000 car, and it calls for SL oil ( making this up, not sure how often they come up with new oils) is SN good enough for that motor?
Or do I have to have an engineering degree to be able to figure out the lawyers / engineers terminology in the actual specs?
Old 03-05-2020, 01:32 PM
For 2020 cars?
Yeah it is older but still applicable. SN is backwards compatible. SP is the
next spec to be used and is scheduled for May of this year. They skipped
the SO so they don't confuse democrats, uh, oh I mean morons...
There is some issues with backwards compatibility with some of the Diesel
engine oils as they have split in recent years. I don't own anything new
enough to worry about it. But if that comes up as a question we can review
it then.
https://www.api.org/products-and-ser...oil-categories
Old 03-05-2020, 01:47 PM
astronut's Avatar
astronut astronut is offline
Simple and to the point info in the video. Thanks Shade!
Lincoln Weld Pak 100
Giant Tech Arc 200
Miller Roughneck2E
Old 03-05-2020, 02:34 PM
MotorDoctor's Avatar
Karma Avenger
I looked up the specs for the wife's Honda HR-V 2016. There's no "S" rating listed in the owner's manual.
Honda Genuine Motor Oil
• Premium-grade 0W-20 detergent oil with an API Certification Seal on the
container
This seal indicates the oil is energy conserving and
that it meets the American Petroleum Institute’s
latest requirements.
Old 03-05-2020, 02:49 PM
on the container This seal indicates the oil is energy conserving
and that it meets the American Petroleum Institute’s latest
requirements
So that would be API Service SN as of today, in a 0W-20 viscosity grade;
and SP starting in May of this year.
Old 03-05-2020, 03:11 PM
Karma Avenger
Thanks. I figured that. I'm sure the actual bottle of oil from Honda has it listed on the back also.
Old 03-05-2020, 04:09 PM
nelstomlinson nelstomlinson is offline
So for my mid-'80s Ford Navistar diesels, and my mid-'70s Deeres, should I:
Use CK-4, which is current?
Use an oil which claims to meet CJ-4?
Or do I need to try to source CI-4 or CH-4, which are the last ones to mention being compatible with the CD or CC specs my old engines were designed around?
Old 03-05-2020, 05:19 PM
CK-4 is find to run in them, if your engine manual states SAE 15W-40, you
can use that or a SAE 5W-40 or SAE 10W-40 with no worries. If you have
an engine that states to use only a monograde oil like SAE 40 like the Detroit
Diesel 2 strokes then you should find a monograde, CITGO has it.
The reason the CC or CD are no longer mentioned is that testing is no longer
performed. But even when it was it was more for the test method and not
every formulation.
Stay clear of the F series for diesel engines unless you have an engine that
specifically calls for it. And then only use the F series products.
https://www.api.org/products-and-ser...l-c-categories
Old 03-05-2020, 05:48 PM
every formulation.
Drat, you had to mention Detroit Diesels, didn’t you. Guess I better check the oil I use and do an oil change in my loader this year. I think I have only added maybe a quart or two since the last oil change 15 years ago.
