Old 02-15-2020, 01:53 PM
Lu47Dan's Avatar
Lu47Dan Lu47Dan is offline
Connoisseur of Old Iron
Default Picked up at work today.
The company I am working for has a policy of not repairing pallet jacks. For the cost of a new one, fixing one is not cost effective. So I offered to pay scrap value for them. This was a couple of weeks ago. Last night I showed up for work and was told I could have them.
Three 5500lb. capacity pallet jacks.
Photo#1 OEP brand.
Photo#2 Mobile brand.
Photo#3 Mobile brand.
The OEP one I think needs fluid, the two Mobile ones need the bearings replaced in the front rollers.
Dan
ID:	154808   Click image for larger version
ID:	154809   Click image for larger version
Miller XMT-304 Multiprocess
Miller 10-E Wire Feeder
Hobart AC/DC stick welder
Hobart 175 Mig
Craftsman O/A set
Turbo torch and B-tank
Old 02-15-2020, 02:01 PM
That’s a You Suck in my opinion!!
Seems strange, I’m actually starting to watch for one, and lots of guys on here are scoring them right now.
Old 02-15-2020, 02:25 PM
Tim KS's Avatar
Tim KS Tim KS is offline
Master Procrastinator
Photo#1 OEP brand.
Dan
So? What is the scrap value of a P-jack there? It may make a difference on the suckage amount.
Old 02-15-2020, 03:07 PM
You suck for sure!!!!!!!!
Old 02-15-2020, 03:30 PM
astronut's Avatar
astronut astronut is offline
You Suck!
Lincoln Weld Pak 100
Giant Tech Arc 200
Miller Roughneck2E
Old 02-15-2020, 03:36 PM
Good to see you are working again
Dan.
Old 02-15-2020, 03:45 PM
Lu47Dan's Avatar
Thanks guys.
Total weight for scrap value around 450#.
Been looking for a used one for years, but they were usaully priced too high or total junk.
Will take off one of the good front rollers, and buy new bearings(8) for both of the Mobile (yellow). The OEP (tan) one most likely just needs the fluid topped off, I have a quart of fluid in the shop. Will most likely keep one of the yellow ones and the OEP one, and give the other yellow one to my neighbor.
Dan.
Hobart 175 Mig
Craftsman O/A set
Old 02-15-2020, 05:07 PM
We have at least three that say it, so it must be true.
******************************** Click image for larger version
Old 02-15-2020, 09:21 PM
Nice score. They are great to move heavy loads around for sure.
Old 02-19-2020, 07:38 AM
Default pallet jax
they run about $350 for a 5500lb manual pallet jack here in MD..nice score Dan
Not Enough Room
