Old 02-18-2020, 06:10 AM
Default IR comp repair
I rebuilt a IR 2475-5 Type 30 a few years ago that came apart at the crank,bearings were destroyed,came apart inside the case..fortunately the case,crank and heads were unscathed ..so just a crank bearing/rod kit and gaskets and it was back in business.Tough compressors.My advice to you buy the right bearings,put it back together right, and it'l last a long time..you wont regret it
Not Enough Room
Old 02-19-2020, 02:14 AM
gimpyrobb's Avatar
gimpyrobb gimpyrobb is online now
Looks like the last bearing I ordered arrived. I'll see how well it goes back together tomorrow or thurs.
