Old 03-14-2020, 11:25 AM
Default At last, an inexpensve helmet.
Here is the solution for welding with your 110volt flux core machine. You have spent way too much money on the welder and now you don't need to spend the same amount of money on an auto helmet.
It is recommended to use a tight weave on the face shield to keep the BB's out of your teeth.
ID:	155160   Click image for larger version
Old 03-14-2020, 11:36 AM
Aside from going blind, he's going to have some interesting tan lines
Old 03-14-2020, 01:01 PM
And they'll match his pockmarks brown hands
Old 03-14-2020, 05:38 PM
bigb bigb is offline
The Chinese have known about those for years
Old 03-14-2020, 10:02 PM
I once saw some illegals welding rebar with cardboard with tiny holes in it. no glasses. welds didn't look too bad either.
Old 03-15-2020, 02:28 PM
I have welded with NO helmet (looking the other way) using 1/8" 7104 on A.c.
Just shove it in the corner, and it will weld itself just fine.
Old 03-16-2020, 04:41 AM
Gadgeteer's Avatar
Judging from the burn spots on his hat, it appears he's been doing some overhead work, too.
Name:	Hat Spots.jpg
