Old 10-08-2018, 04:29 PM
Nomoreusmc Nomoreusmc is offline
Default Vertical 7018
Got my flat and horizontal the way I want them but I keep leaving a dug out pit in front of my vertical. I ran out of 1/8 and 3/32 is doing the same thing. Been running the rod flat to slightly up.
Sent from my [device_name] using ShopFloorTalk mobile app
Hobart Titian 8000
210mp
Square wave 200
Everlast 160stl
Powerkraft 300
2 Loose Screws Fabrication
Owner
Old 10-08-2018, 07:07 PM
I don't know how they terminate welds when it comes to code welding. Ok, that's said, and done.
Most of my uphill welds are simple fillets that terminate at the top of the joint. One rod is generally enuff to get there.
It's normal to have a "pit" at the forward edge of the weld. You're digging when you go uphill.
On a regular weld...…..enuff rod to do it without a start somewhere in the middle of the weld...…….I run to the top of the weld, and let it flare. Stay on that spot to deposit metal to fill the cavity, even coming back down the weld a bit. It's the end of the weld, so it's just a matter of filling the void any way you choose.
On a long weld, one that requires a new rod somewhere along the way.....I run till my rod is too short, then do a very sharp break. Pull that sucker right off the metal.
Then I strike the new rod well above the pit, and bring it down into the pit. I don't sit there and consciously fill the pit, I just start welding once I'm in the pit. Works out good. You stay too long in the undercut you made, and you build a hump. Just start welding once you're in the void.
http://www.farmersamm.com/
Old 10-08-2018, 07:11 PM
Square tubing presents a different issue.
When going uphill on tubing.....carry the arc up to the upper edge, then run on into the horizontal joint, then bring the puddle back to fill the corner. You need to be careful about sealing those corners when welding tubing. It's easy to f'k up a corner.
Old 10-08-2018, 10:57 PM
Now that you mention it I don't think I have ever stick welded tubing.
I think part of the problem is that I love to bury my flux in the puddle and I am digging out too much.
Hobart Titian 8000
210mp
Square wave 200
Everlast 160stl
Powerkraft 300
Owner
