Old 10-16-2018, 11:09 AM
Lu47Dan's Avatar
Lu47Dan Lu47Dan is offline
Connoisseur of Old Iron
I always thought farmer rod was wet 6013
I think a pissing match is about to start.
I am sure I have worn out a few hundred grinding wheels removing farmer welds out and off equipment that needed repairs.
Dan.
Miller XMT-304 Multiprocess
Miller 10-E Wire Feeder
Hobart AC/DC stick welder
Hobart 175 Mig
Craftsman O/A set
Turbo torch and B-tank
Old 10-16-2018, 11:21 AM
Dan.
I think the new, revised, "Farmer Rod" is now gasless flux core, applied
with a HF 110 volt MIG box.
Sans helmet....
Old 10-16-2018, 11:30 AM
I have about 200 lbs. of that (wet farm rod) sitting out back of the shop ill let go of for .09 cents a pound it's still good and wet might be soaked after the last two days of heavy rain
Old 10-16-2018, 01:18 PM
Back in the day before the wire feeds took over 3/16 Hobart rod was the go to rod if we ran out of that we used 1/4 7018
Old 10-16-2018, 06:58 PM
monckywrench's Avatar
trust but verify
I tap Excalibur on my (ungrounded!) bastard file or crush the extra length of flux before restrikes.
Even "expensive" welding rod is cheap for what it does. Mystery rod (Radnor...) has failed me too often to bother pinching pennies.
We bought a lot of Hobart at the welding school because it was cheaper which matters when you buy pallets. I don't care for it. Excalibur or ESAB Atom Arc work a treat.
We had students practice with Hobart then test using Excalibur or Atom Arc. They were quite pleased by the difference.
