Rest In Peace Cutter
Old 09-21-2018, 07:35 AM
g 213 g 213 is offline
Default Hobart g 213
Hello there i have a hobart g 213 engine driven welder that runs fine. But it will only weld on the maximum setting all the other settings have no arc or power. The fine adjustment seems to work tho on maximum.There is also no power at the 110 or 220 outlets. it will burn rods easily with thick steel on maximum setting. Thanks in advance.
Old 09-21-2018, 09:38 AM
Welcome to the pile. I am not an electrician, so you will have to wait till one comes along.
Woodrow Wilson
Old 09-21-2018, 11:04 AM
We like pictures but please read FAQ as we do them as attachments ,not off site or embedded .
Old 09-21-2018, 06:44 PM
sounds like the control pot is open at the maximum end . When the wiper moves off the end pad the circuit goes open. If this is the case and it is a standard wire wound pot ( the windings are uniform from end to end) you can swap the leads on the end terminals and it should work over the full range but it will be backwards ie ccw will be max current and cw min current.
Old 09-21-2018, 07:57 PM
Nomoreusmc Nomoreusmc is offline
This is right. But I would also expect to see voltage at your outlets when the fine voltage is in it's "welding" position. Get some electrical cleaner and hose the crap out of that pot. Wait 5 min and do it again. Let dry and try again
Sent from my [device_name] using ShopFloorTalk mobile app
Hobart Titian 8000
210mp
Square wave 200
Everlast 160stl
Powerkraft 300
2 Loose Screws Fabrication
Owner
Old 09-21-2018, 07:58 PM
This stuffClick image for larger version
Hobart Titian 8000
210mp
Square wave 200
Everlast 160stl
Powerkraft 300
Owner
Old 09-21-2018, 08:14 PM
I have one (or similar hobart, mine has the 2 cylinder Wisconsin)
IIRC the pot is bad, as stated above.
I added a locking plug and remote/local switch to dis-able
that pot, and put a identical one in a box on a cord.
Old 09-28-2018, 07:40 AM
Thanks for the help i will try that when i get home
Tags
electrical, engine driven welder, hobart
