Old 01-10-2013, 10:27 AM
joeyboots1212 joeyboots1212 is offline
H80N:
thats the exact cord I have ordered. I also picked up a pigtail but couldnt find the 6-50 receptacle to wire it to. I couldnt remember the link from the other thread or what exactly it was I needed so I was a little uncertain as I shopped around. Maybe they were just out of them. Do you recall the link?
Now on to my update:
I did try the plasma plugged directly into the wall and also prepped the metal well. Just a very minimal dimming of the lights so that was WAY better but still did not perform well and so I am wondering if alot of that is the 110 aspect (or perhaps just my inexperience!). Once I get the extension cord squared away we shall see if it makes a difference.
I also tried the tig. Admittedly my only experience to date has been mig and stick so its all new to me. The unit worked ok in that it didnt trip the breaker on 110 and barely caused any dimming or anything. I did however have trouble regulating the argon (see my upcoming seperate thread) and forming a puddle. I kept burning up the tungsten. And FWIW I was practicing on aluminum. I know its more difficult but the steel consumables had not arrived yet so its all I had and I was anxious to start. So not sure if it was the gas issue, my inexperience, using it on 110, or all of the above. I will say I am anxious to practice more however!
Old 01-10-2013, 10:34 AM
H80N's Avatar
H80N H80N is offline
That Man Behind The Curtain
Originally Posted by joeyboots1212 View Post
H80N:
Try this link...
http://www.lowes.com/pd_71246-334-12...7C1&facetInfo=
Do not believe you will get enough amps on 115v to do any useful aluminum welding....
Old 01-10-2013, 10:44 AM
I couldnt for the life of me find that...thanks!
One last (hopefully) thing, is it possible to cut off one end then attach the 6-50 receptacle to that end of the extension cord? I only ask as I was wondering if it would be advised to minimize the number of connections. Was just worried about the welder plugged into the extension cord plugged into the adapter plugged into the dryer outlet. If its not an issue then no worries, just thought I would check!
Old 01-10-2013, 11:04 AM
H80N's Avatar
Sure you can cut it off...
But I would not do it...
having separate adaptors ... rather than ruining the extension for future uses
strikes me as preferable... and is what I have done..
my little TIG machine (Dynasty 200DX) gets dragged around to all manner of shops and garages... so I have made up a whole collection of adaptor pigtails...
just my 2cents worth..
Old 01-11-2013, 11:52 AM
just want to make sure i am not overlooking anything....on the pigtail the middle is the ground and goes to the middle terminal...and the outside ones are the hots. anything else recommended for the adapter or is this all i need?
Old 01-11-2013, 12:24 PM
rickairmedic's Avatar
SFT HVAC Guru
Joey you have the pigtail figured out center ground outside hots . Remove the crimped on connectors and strip back so you have bare wire to go into the adapter under the luggs. Lay the wires onto the adapter so you can cut them back and strip them to fit neatly inside of it .
Rick
Old 01-11-2013, 12:27 PM
Looks OK
Old 01-11-2013, 12:35 PM
H80N's Avatar
The only thing I would add other than double checking the connections...
is...
to run the pigtail through a couple inch length of rubber heater hose at where it clamps to the 6-50 receptacle for a strain relief...
Old 01-11-2013, 12:46 PM
perfect...thanks guys!
Old 01-25-2013, 04:14 PM
so here is an update. very impressed with switching to 220...gotta say both the plasma and the tig seem to work pretty nice. eastwood is a good unit. still getting used to it...i have been practicing. as you can tell i am still getting used to it...burned through a couple times. but i am having fun with it and looking forward to honing my skills.
