Old 02-05-2009, 02:41 AM
ace4059 ace4059 is offline
Tender Member
Walker,
your plasma ground looks thicker than the wire on my Hyper 600. My wire looks like it is about 18 ga. Is that the factory wire on yours?
Lincoln Pt 225
Lincoln PM 215
Lincoln Buzz Box
Hypertherm 600
HH125 EZ
MM 350P
TB 302
Calling an illegal alien an "undocumented immigrant" is like calling a drug dealer an unlicensed pharmacist.
Old 02-05-2009, 10:05 AM
Yeah its factory. If I were to gues the wire is about a #10 and the insulation is a very heavy rubber.
Old 02-05-2009, 11:59 AM
panhandle_redneck's Avatar
panhandle_redneck panhandle_redneck is offline
No I wasn't knocking your unit, Walker. I have the exact same unit 2-3 years old and I have had a few problems like you are describing. Never woulda thought about a ground problem. I always thought it had to be cleaner than my welders grounds. Thanks
Old 02-05-2009, 12:24 PM
Paychk's Avatar
Paychk Paychk is offline
Project Phoenix
Originally Posted by ace4059 View Post
here is a pic of one
https://weldingsupply.securesites.co...+Ground+Clamps
the part number is GC-300 off of weldingsupply website, your LWS part number maybe different cost is about $25. and I have 3/0 cable on the 350P (20 ft)
That clamp is a little more than what you need on a plasma cutter.
I burned my hand once (through the glove) on it when welding 1/2" pipe with 400+ amps. I grabbed it after welding for about 2 hours. But the clamp is now all sorts of pretty colors.
Thanks
Ory-gun Boy!
Old 02-05-2009, 12:38 PM
Alan, I'll bet you a faux-silver dime against a cooper penny that he meant to say copper clamp.
Old 02-05-2009, 12:49 PM
Paychk's Avatar
Project Phoenix
I'd say your right, after I saw the pic.
Ory-gun Boy!
Old 02-05-2009, 01:11 PM
I went out and checked the Hypertherm Powermax 1250 I have, I did change the clamp that came on it, it broke after being run over by a truck, the new one is from Miller, and is the one I use on all of my welders. The ground wire in my plasma cutter is a #6 wire, a small diameter welding cable with rubber insulation.
ID:	41310   Click image for larger version
Old 02-05-2009, 04:42 PM
Tender Member
I thought cooper didn't look right when I was reading over it but the spell check didn't underline it so I didn't think twice about it. Yes I meant for it to be COPPER. And as you can tell spelling isn't my best subject.
Lincoln Pt 225
Lincoln PM 215
Lincoln Buzz Box
Hypertherm 600
HH125 EZ
MM 350P
TB 302
Old 02-05-2009, 04:53 PM
Join the club. Just accept from time to time Shade or Rod is going to poke a little fun at you.
Old 02-05-2009, 05:27 PM
Spellcheck didn't pick it up because cooper is a word, as in a cooper, a barrel maker or as a name, like Gary Cooper, spellcheck will tell you if the word is spelled wrong, if you the typer picks the right word to begin with.
Jack
