Old 03-31-2020, 05:24 PM
Default You Don’t Need a Sheet Metal Brake
Unless you are bending on a regular basis I would agree that a heavy steel table is much more useful/versatile than a metal break in most metal shops. I bought a 48” leaf break some 25 years ago. I don’t think I have used it ten times since then. In fact it is hiding in my storage room and I haven’t seen it in several years.
This steel sheet is .082” (2mm) thick and 30” long. The table it is clamped to is some sort of tooling plate I bought from the scrap yard. It is Blanchard ground and weighs 1800 lbs.
The 2x4 wood block and 8 pound hammer were also used to make this bend.
Old 03-31-2020, 09:01 PM
Nice.
If there is a will there is a way.
Old 04-01-2020, 06:05 AM
So you own a perfectly good brake, but decided to bash it with an 8lb hammer instead...."Classy"....
Old 04-01-2020, 06:47 AM
What do you expect from a man who doesn’t have a properly functioning toilet and shits on the printed faces of good looking well adjusted people?
Old 04-01-2020, 07:25 AM
Some tips for doing something like this:
1- Like the anvil the bigger the better. Having more mass underneath will transmit more energy into the work rather than it being absorbed.
2- Preloading is important when you have a long stick-out leg like the set up shown in the picture. I like to add as much force to the bend as I can without causing any permanent bending. In the picture you can see about 100 lbs. of steel blocks clamped to the outer edge. As the bend progressed downward the weight was less affective so I added a chain hooked to the C clamp under the table and a turnbuckle on top. This not only makes the hammering process much easier, it also prevents the long leg from deforming because of the inertia it possesses.
3-Choose the right hammer and corking tool. Hammer size depends on the mass of the structure it is hitting and the width of the corking tool. As a rule the higher the mass underneath and the wider the corking tool the bigger the hammer should be.
I have bent up to 1/4” plate steel using these techniques. That process involved a 16 pound hammer and a special made corking tool on a three foot rod held by another person.
Old 04-01-2020, 07:29 AM
The finished bend.
Old 04-01-2020, 09:39 AM
I like your table, nice find.
