Old 04-02-2012, 09:05 AM
Originally Posted by Paychk View Post
I remember the first Bobcat I ever operated, I couldn't get it to idle, then I noticed the ignition switch is set up as "off - run/idle - run - start", so they won't go to the run/idle mode automatically, they have to be placed there. This was changed on the latter ones to "off - run - run/idle - start" so run/idle was the default mode then the start switch was released.
I thought it was odd that the default was full run too. I do get 13.5 volts to the throttle solenoid when switched to the run/idle setting, so it is not a wiring issue.
Old 04-02-2012, 09:58 PM
Paychk's Avatar
Paychk Paychk is offline
Project Phoenix
Might be the plunger in the solenoid is hanging up?
Ory-gun Boy!
Old 04-02-2012, 10:04 PM
Fluid film!
Old 04-02-2012, 10:22 PM
Fluid film!
EXACTLY what I did. It seems to have made the plunger slide more freely. Gonna give it another try tomorrow morning.
BTW, thanks Cutter. You just reminded me to get some more FF. Just got a case of 12 cans for $7.09 a can with free shipping on Ebay.
Old 04-02-2012, 11:50 PM
DDA52's Avatar
DDA52 DDA52 is offline
Blood, Sweat & Concrete
The newer 225G's have a cover over the plunger. The older ones like mine, were exposed and needed some help now and again.
Don
Old 04-03-2012, 03:00 PM
Thread closure time. Got the adjustment done on the idle down. Works right. Set the high speed engine RPM by measuring the AC cycles. It was off by 2 so reset the full throttle speed to get 60 cycles per second. Still have to add an in-tank fuel filter in order to keep crud in the fuel from getting up to the carb. Other than that all done. Thanks everyone for their advice.
Old 04-03-2012, 11:20 PM
Paychk's Avatar
Project Phoenix
Did you put a load on that when you reset it to 60? The engine may pull down under load & end up @ 58 Hz.
Ory-gun Boy!
Old 04-04-2012, 07:51 AM
Yes, we did out a load on it. The rpms came up to match the load and it stayed at 60 cycles. Good question though.
Just to see how sensitive the unit was, I plugged in a cell phone charger with the phone plugged in while it was on the run/idle and it kicked out of idle and upped the rpms to the 60 cycles. I was pretty surprised to see it could detect such a small load.
Old 04-04-2012, 08:22 AM
tnmike's Avatar
tnmike tnmike is offline
Sultan of Scrounge
I had a chance to buy one for 1500 bucks one time and let it get away. I thought that was a good deal. This is a great deal with the trailer.
Now all you need is the MIG gun for it.
Klaatu barada nikto
Old 04-04-2012, 08:52 AM
I have to admit that my little 110 fluxcore mig is very limited and a suitcase style would be a nice addition to this welder. Maybe the next auction????
