Old 02-02-2009, 06:08 AM
moe1942's Avatar
moe1942 moe1942 is offline
Voice of Experience
Originally Posted by tiptop View Post
I hate to see that stuff happen. A guy had a similar problem on the HSM board and he built a new piece. The one he built looked much better in cross section than the stock one. I was considering a similar lathe and then I found my 14C Monarch 16X54 with every attachment known, paid about 1K more for the Monarch.
Jay
Jay I remember seeing that and it came to mind after the accident. Think you can put your hand on it again??
moe1942's Avatar
Voice of Experience
I have been thinking of removing my compound feed and replacing it with a post or plinth. On a friends Emco he did that, but of course the thing has Tee slots the full length of the cross slide.
It seems to give a lot more rigid support that way and putting the compound back on is easy when you need it for threading.
When doing jobs that really need to max out the lathe capabilities, it seems it would be stronger
Looks like a plan..
Old 02-02-2009, 06:09 AM
moe1942's Avatar
Voice of Experience
I bought a rough casting kit to make a new cross slide top for my 12" x 54" Atlas lathe, the original casting on the Atlas is a weak point, and this more than doubles the thickness of the cross slide. It also gives 6 t-nut slot across the whole length of the slide top. The also sell kits for the upside down parting tool cutters and as well as other stuff. the link to the company is www.sc-c.com/metallathe
Now Jack that is the ultimate solution. I'll be looking for one. Thanks.
Old 02-02-2009, 10:28 AM
Platy, thanks.
You're a scholar and a gentleman...no matter what they say:evil:
Old 02-02-2009, 07:52 PM
pawtech0's Avatar
pawtech0 pawtech0 is offline
Originally Posted by moe1942 View Post
This is the third friggin time I have tried to post this. Keeps disappearing before I finish...
The main problem is the original hold down bolts were too puny to do an adequate job. I will fit two T nuts to grab all the meat available and cover a longer area. Also will fab a support for the front of the compound to take up most of the force. That should work.
One other thing. We removed the saddle from the apron and saw another horror story. When the apron is filled to the right level in the sight glass it does't reach any gears. They were as dry as a March wind in Lubbock..I told Dave to fill the damn thing up til it runs out of the highest point and make a dipstick marking about an inch lower. Its slinging oil now. Things sound better and engage smoother. The headstock gears will get the same diet..
I would recommend anyone with a chinee lathe to investigate.
Moe can you post pics of what the hold down bolts look like I took mine off and they seam to be gripping all that there is to grip my g4003 is not quite a year old and I'm wondering if they changed them .Also about the oil problem when I bought it the grizzly salesman told me the first thing to do is get rid of the china oil so I pulled the top off headstock and pumped it out and filled it with the top off and also drained and filled the saddle.
_____________________________________ Phil
Old 07-20-2014, 07:18 AM
Originally Posted by Fla Jim View Post
I think I read some where that "parting is such sweet sorrow".
Using the parting tool is my least desirable lathe task, right next to knurling.
I bet that was a drawers changing experience. I'm glad he wasn't injured.
Me, I'd ten times rather knurl than use a cut-off tool. :-)
...lew...
Old 07-20-2014, 09:57 AM
Twice the size--half the man
I missed this thread the first time around, either for lack of knowledge on the subject or it just slipped my radar.
Big Blu's poor excuse for a compound hold-down isn't much better than what's shown in the pics here, and only has a two point mounting system. A couple different companies make a 4-point system but I keep telling myself I'll make one myself one of these days. I fully expect a catastrophe like this to destroy it before I get that done.
I regularly groove with a custom cut .140" tool I made for o-rings. It has some serious grabbing power when things start to get too sticky, but usually my fixture breaks before any part of my machine. Good to build that sort of thing into your setups when you have the chance .
I'm getting pretty confident with regularly parting off work on smaller pieces, at high speed, lots of oil, and continuous feed. Indeed though, when things go wrong it does so in a hurry and will almost always cause your heart/body to have reactions you wouldn't want to display in public .
Wade's Custom Kydex
