Old 02-01-2009, 01:41 AM
Dave Lee's Avatar
Dave Lee Dave Lee is offline
Armchair Webbie
From what I've read, the British, seem to be fond of parting tools mounted on the back of the cross slide. The blade is mounted upside down and the chips are pushed down, out of the cut, while the lathe is running forward, as usual.
I wonder, if that would work on this lathe?
Of course, the compound still needs beefing up.
Dave
Old 02-01-2009, 08:01 AM
Fla Jim's Avatar
Fla Jim Fla Jim is offline
Harbor Freight Backslider
I think I read some where that "parting is such sweet sorrow".
Using the parting tool is my least desirable lathe task, right next to knurling.
I bet that was a drawers changing experience. I'm glad he wasn't injured.
Jim the Shop Rat
From Jim’s Magic Garage®
Old 02-01-2009, 08:19 AM
moe1942's Avatar
moe1942 moe1942 is offline
Voice of Experience
This is the third friggin time I have tried to post this. Keeps disappearing before I finish...
The main problem is the original hold down bolts were too puny to do an adequate job. I will fit two T nuts to grab all the meat available and cover a longer area. Also will fab a support for the front of the compound to take up most of the force. That should work.
One other thing. We removed the saddle from the apron and saw another horror story. When the apron is filled to the right level in the sight glass it does't reach any gears. They were as dry as a March wind in Lubbock..I told Dave to fill the damn thing up til it runs out of the highest point and make a dipstick marking about an inch lower. Its slinging oil now. Things sound better and engage smoother. The headstock gears will get the same diet..
I would recommend anyone with a chinee lathe to investigate.
Old 02-01-2009, 08:37 AM
Fla Jim's Avatar
When I got my used "Rotger lathe" The sight glass on the headstock was clouded. I took the top cover off to inspect the condition, when I changed the oil. The middle of the sight glass is the appropriate height for the oil level on mine.
Jim the Shop Rat
Old 02-01-2009, 10:46 AM
moe1942's Avatar
Voice of Experience
Well the middle of the sight glass on the 4003 apron is 3/8 inch below the lowest gear..
Old 02-01-2009, 11:29 AM
SlimJim's Avatar
SlimJim SlimJim is offline
Founder: Machining Forum
Originally Posted by moe1942 View Post
Jack, Grizzly is shipping out a new cross slide. Took it off another lathe. No questions asked. I told him to sen the pics I took so they would know why.. All the damage was confined to the cross slide.
I wonder if it was "no questions asked" because they have seen it a lot before?
Director of Purchasing
Tact is for people who aren’t witty enough to use sarcasm.
Old 02-01-2009, 12:08 PM
moe1942's Avatar
Voice of Experience
I said the same thing slim..
I wiil say the center area especially where it's thin is not meant for stress, it just provides a swivel for the compound. All the stress is really handled by the undercut in the cross slide. After looking it over good I believe the root cause of the failure is sloppy hold down studs. This same lathe has been around many years with good performance. Like most imports they need tweaking. Best before failure though.
Old 02-01-2009, 05:26 PM
tiptop
Guest
Posts: n/a
I hate to see that stuff happen. A guy had a similar problem on the HSM board and he built a new piece. The one he built looked much better in cross section than the stock one. I was considering a similar lathe and then I found my 14C Monarch 16X54 with every attachment known, paid about 1K more for the Monarch.
Jay
Old 02-01-2009, 08:53 PM
Ironman Ironman is online now
Originally Posted by OLD MAN View Post
Moe, from the photos the cast looks kind of porus or low quality. I have been looking at one of those. I might better off with an old South Bend. I have no experience and there will be mistakes. You rated it highly, do you still feel that way. Is there a way to beef up the replacment part? The good thing is Grizzly will have the part and will get it to you quick. Was everything else ok. I hope he wasn't hurt.
I have been thinking of removing my compound feed and replacing it with a post or plinth. On a friends Emco he did that, but of course the thing has Tee slots the full length of the cross slide.
It seems to give a lot more rigid support that way and putting the compound back on is easy when you need it for threading.
When doing jobs that really need to max out the lathe capabilities, it seems it would be stronger
Name:	Plinth to replace crossslide.jpg
Old 02-01-2009, 09:29 PM
platypus20 platypus20 is online now
I bought a rough casting kit to make a new cross slide top for my 12" x 54" Atlas lathe, the original casting on the Atlas is a weak point, and this more than doubles the thickness of the cross slide. It also gives 6 t-nut slot across the whole length of the slide top. The also sell kits for the upside down parting tool cutters and as well as other stuff. the link to the company is www.sc-c.com/metallathe
Name:	cross slide 003x.jpg
ID:	41125   Click image for larger version
Name:	cross slide 007x.jpg
ID:	41126   Click image for larger version
Name:	cross slide 008x.jpg
ID:	41127   Click image for larger version
Name:	cross slide 010x.jpg
